What kind of PT Cruiser do I have, and what engine?
Like Tree8Likes
Old 25 Apr 2018, 02:02 pm
Default What kind of PT Cruiser do I have, and what engine?
I have been wanting a PT Cruiser for a long time. I love the retro look to it. I just acquired a 2005 PT Cruiser convertible. It definitely needs some work, so I am going to restore it.
1) Looking through websites for parts, I need to know exactly what model it is. According to J.C. Whitney.com website, I understand that, for model year 2005, there is a "Base", a "Dream Cruiser", a "GT", a "Limited", a "Street Cruiser" and "Touring". I don't see any of those appellations on the outside of the vehicle... can I assume it is a "Base" model?
2) I also understand that, according to Autozone.com website, there are several engines for this model year: "4 Cylinders 8 2.4L MFI Turbo DOHC", "4 Cylinders B 2.4L MFI DOHC", "4 Cylinders E 2.4L MFI Turbo DOHC", "4 Cylinders G 2.4L MFI Turbo DOHC", "4 Cylinders S 2.4L MFI Turbo DOHC", and "4 Cylinders X 2.4L FI DOHC". How can I find out what type of engine my vehicle has?
If it helps in ID'ing it, it has a five-speed manual transmission.
Many thanks in advance for any suggestions, advice, ideas or other words of wisdom!
Old 25 Apr 2018, 02:40 pm
Default Re: What kind of PT Cruiser do I have, and what engine?
The 8th letter/number of your VIN number will tell you the type of engine you have. It's on a plate visible thru the lower left windshield.
Handy_Cruiser likes this.
Old 25 Apr 2018, 04:23 pm
LionPT's Avatar
I believe the only models of convertible were...Base, Touring & GT.
Old 01 May 2018, 05:54 pm
rckstein's Avatar
Welcome to the forum
I was going to post this a few days ago but the Dodge website was down.
You can find out everything about your PT by getting the Build Sheet for it.
Go to this website:
https://www.dodge.com/webselfservice/dodge/index.html
In the left-hand column under YOUR VEHICLE
click on Equipment Listing
On the next page that loads in the white box in the middle enter the VIN then click the red Search button.
The next document will be the Build Sheet for your PT.
Old 11 Jun 2018, 11:54 pm
brian2002utd's Avatar
I have a 05 Vert as well. The touring edition would have come with stock alloy wheels where as the base would have steel wheels with a plastic "beauty cover." The touring had 2 engine options, naturally aspirated or turbocharged. The turbo would be easily identifiable as it would have an aluminum intake manifold as opposed to the stantard plastic. The valve cover would also be aluminum. If its a GT than you have a high output turbo and i believe a different looking speedo cluster. If you find that its a turbo I would recommend getting a OBD2 bluetooth module and downloading an app called torque pro. It will allow you to see what your PSI boost is based on MAP sensor readings. Some non GT turbos have been modified to meet or exceed GT specs. The boost reading would be an obvious indicator of that.
Handy_Cruiser and CRUZ like this.
Old 12 Jun 2018, 12:01 am
Also I don't believe there is any difference parts wise for the several different turbo engine codes you will see on the AutoZone app or web site. It confused me at first as I have a turbo. Parts should be interchangeable across all those turbo engine codes to my knowledge. Even the GT turbo has all the same parts, the regular turbo is merely downtuned to 7PSI boost so you can run regular grade fuel. If you have any other questions feel free to ask. We have 3 PTs in this household!
Old 12 Jun 2018, 06:52 pm
Handy_Cruiser's Avatar
The 2005 Dream Cruiser only came one color that's a dark taupe. It also has all the GT stuff.
The 2005 GT will have 17 inch wheels, turbo and Autostick shifter or 5 speed manual. Leather seats.
The 2005 Touring Vert has 16 inch wheels, an auto tranny with regular seats. Turbo and leather are optional.
2005 Base model has 15 inch wheels. They are usually steel with hubcaps. Tranny is auto or 5 speed manual. Seats are cloth. No turbo option.
CRUZ likes this.
Old 18 Jun 2018, 03:40 pm
Fk5 Fk5 is offline
I thought that the composite manifold was a running change? I can't remember if it was 2004 or 2005, but at least part of the year should have the composite manifold for turbo and NA Cruisers.
2003 GT 5 speed
162,000 miles
Old 18 Jun 2018, 04:07 pm
For the turbo PT's, 2003 and 2004 had aluminium intakes. Most 2005 GT's got plastic intakes. 2005 Turbo Lites got a mix of aluminum and plastic. From 2006 on, most all got plastic.
And of course, all non-turbo PT's have plastic.
Fk5 likes this.
Old 30 Dec 2018, 08:51 am
chabnormal's Avatar
I have a 2006 Convertible Touring Turbo Lite with the automatic transmission. I love it. It's hard to explain unless you own one. I tell people about the car, "it's made for people that like to drive fast but not for people in a hurry." I got it in 2016 with 43K miles and it was garage kept or parked out of the sun. It seemed great at the dealership until it sunk it that the car had to have sat, a lot. I live in Florida on the First Coast and the climate did a number to the rubber... well everything. I've spent the last couple of years replacing just about everything save the engine (thankfully), transmission (pure luck), turbo, or starter. I've spent more money in repairs than the cost of the car, but I don't think I'll ever get rid of it. I drive my car a lot and not exactly lightly, 50+ miles to work. I drive it in months of high 90's temperature and high 90's percent humidity. In 2 and a half years I put 70K more miles on it. The only time it has ever broken down though was when the belt snapped. FYI, don't keep trying to start your car if it breaks down.
A word of advice to anybody with the turbo automatic, DO NOT move the gear shifter unless the car is stopped and the RPM are at idle. I usually let my cars settle down to normal idle RPM before I drive off. I have owned 7 cars in my life and I have never had the problems that I had with this car until I realized the importance of doing this. Apparently the transmission is more complex than regular automatics and the synchronizers weren't... well synchronizing. It was affecting EVERYTHING. The car has 2 computers. One for the engine and one for the transmission (and suspension, crazy).
I was wondering if anyone else has a automatic turbo in Florida? I was thinking about upgrading from the K&N filter to the complete K&N air box, but the engine already runs on the hot side and it looks like it would draw in a bunch of hot air from the engine compartment. Has anyone else had engine heat issues.
What Kind Of Performance Chips are available for a 2001 pt cruiser non turbo???? cpolston227 General PT Cruiser Discussions 2 22 Mar 2010 05:03 pm
For Sale, One of a Kind Supercharged PT Cruiser bigslim Classifieds: For Sale/Trade 5 27 Apr 2006 12:45 am
What kind of video do you have in your Cruiser? PT Lilly Sound and Security Forum 20 05 Aug 2005 03:53 am
What kind of Gas do you put in your Cruiser? PTWoody General PT Cruiser Discussions 19 08 Jun 2004 04:21 pm
Close Encounter of the Cruiser Kind PTucker General PT Cruiser Discussions 25 15 Feb 2004 10:46 pm
