Hello, I have Lowed the GT front and back. I still have a gap on the back of the car. I want to get rid of the gap.What can I do to achieve this? 2inches on the back 1.5 on the front.
This is a bad idea. They are there to use the street term "bump stops", and are design to absorb and slow down the axle when the springs become so compressed the axle makes contact them. Even trimming them is a bad idea unless it is absolutely necessary and should only be enough for clearance with a full tank of gas..
As for lowering the PT Cruiser... I have to ask before the PT was lowered what was the measurements of the front and back? This is always a requirement to install lowering springs correctly but not always worded this in the installation instructions of the springs. Before any suspension modification like springs the first thing to do is to completely check the suspension for correct specification. Unless the PT cruiser is going to be for parking lot shows it really is better on this platform to have a slight increase in the rear suspension over the front. Unless the intended use will never have luggage or other passengers.
Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() Last edited by NitroPT; 06 Dec 2018 at 09:30 am. |
Go old school: bigger tires on the rear. I tried it and decided to go bigger tires ( 225/60 15) all around.
![]() '02 base, 5 spd, HAHN turbo kit & some other stuff. |
![]() Quote:
That said, I haven't had them back on since I put -30's and KYB's on the back end, which made a nicht and day difference to all aspects of handing and ride as my old shocks were the 370,000Km plus originals.
_________________________________________ '07 2.2 CRD |
![]() Quote:
![]() On chopping the bump stops, I have nothing against chopping them roughly in line with how much you lower - eg, 20mm off for a 30mm drop. What I don't like seeing is people just chop a lump off in situ. The bump stops are graduated with a thin wall section to begin (ie, closer to the axle) with gradually stiffer sections after that towards the turret. If they're going to be chopped, they should at least be taken out of the turret and chopped at the end that goes into the turret - not the graduated end. If you look at the stops once they are out of the trurrets, you can see where to cut and retain a "ring" that fits over the depressed grip formed in the turret to hold them in place.
Thread Tools | |
Display Modes | |
Can PT front seat back upholstery be interchanged, non air bag to air bag seat back. | ptprice | General PT Cruiser Discussions | 4 | 06 May 2017 02:59 pm |
Going Lower? | Teckspeed | Wheels, Tires, Suspension | 4 | 22 Sep 2011 02:16 pm |
Hump back hatch back conversion... | Metaltwister | Exterior Accessories Forum | 48 | 14 Sep 2011 11:00 pm |
better put your back seats back | Ctown | General PT Cruiser Discussions | 0 | 26 Feb 2006 11:21 pm |
