Could be a thousand reasons. Something shorted, bad fuel pump, ignition. First test the fuel pressure, then spark, etc. I've had one bad injector short out all the injectors once. Worst thing to do is get hung up on a theory.
Welp guys i pulled off the camshaft sensor and it’s not turning when i try and crank it. From everything I’ve read i believe you guys are fixing to tell the timing belt broke. Sounds like classic PT cruiser at my mileage.
Brand new battery and won’t turn over. Sucks |
![]() Quote:
I was told if you take off the camshaft sensor and the camshaft is not turning while cranking the car...that means the timing belt broke.
Its all over the internet. The car will not crank. You turn the key and it tries to start but won't turn over. This is how I ran down my battery and had to buy a brand new one so I only tried it a few times this time. If this is not the right way to check it then explain. PO340 and I replaced the sensor and it still won't start with new battery. |
![]() Quote:
![]() Thought crank and turn over meant the same thing. |
![]() Quote:
If at First You Don't Succeed - Try, Try Again |
How many miles were on the pt when it broke? I am on borrowed time on my belt and just wondering how long I might have.
Saying your car won't crank generally means that the engine is locked up and won't spin. In your case, the car cranks but won't start, correct? In that case, the first thing to usually check is the timing belt. Seems like you figured that out by observing the camshaft is not turning. Terminology varies from region to region and that's probably part of the confusion. What I call valve cover gasket, some others refer to as head cover gasket.
![]() Aspire to inspire before you expire. |
![]() Quote:
We have to get the terminology down. First thing is if the engine turns - which most of us consider cranking. Next is if it fires. Some people refer to this as turning over, which can contribute to the confusion. If it is the timing belt it will usually crank faster than usual because the top half isn't spinning. At least that was my experience (T1 2.2). You might not notice this because of the battery issues, but it sounds like you have confirmed.
2003 GT 5 speed 162,000 miles |
Thread Tools | |
Display Modes | |
05 just died while driving | ilovemyducks111 | Tech & Performance Forum | 5 | 03 Apr 2016 05:20 pm |
pt died while driving nd won't start | gabe1016 | General PT Cruiser Discussions | 7 | 28 Jan 2015 11:10 am |
2001 Died while driving | compguy | Tech & Performance Forum | 3 | 07 Aug 2013 11:43 am |
My PT DIED WHILE DRIVING | thequadx | Tech & Performance Forum | 11 | 06 Feb 2013 08:05 pm |
2003 PT Cruiser died while driving | tlm | Tech & Performance Forum | 6 | 24 Sep 2011 01:47 pm |
