water leaking in
Old 05 Jun 2019, 07:56 pm
Default water leaking in
my daughters 2007 pt has a problem that i cannot find an answer for i'm hoping someone here might be able to help. we had a heavy downpour a couple of nights ago and even though the car didn't move there is water sloshing around inside and is coming out of the blower motor( or it appears to be) the motor still works and you can here the water moving while driving,
i have checked the cabin filter and cleaned out the drain hole at the bottom of the front wings but water is still getting in, where should i look ,
thank you
Anthony
Old 06 Jun 2019, 06:29 am
LionPT's Avatar
Default Re: water leaking in
That could very well be a heater core leak...the rain was just a coincidence.
Old 06 Jun 2019, 07:42 am
Does her PT have a sun roof? If so, the drains are probably clogged. Although if you can hear the sloshing, LionPT is most likely on the right road. Have you tried clearing the a/c drain pipe? Maybe it's clogged.
Old 07 Jun 2019, 08:32 pm
it happened before , last time we had bad rain , abouit 2 months ago , i checked the drain then and cleaned out the bottom of the wings which were pretty full of old leaves, there is no water leak so i doubt if the heater core is leaking , its a convertible so no sun roof, i will look at the ac vent that's a good idea , would that leak back into the car?
Anthony
Old 08 Jun 2019, 07:25 am
Yes, if it's clogged. The water has nowhere to go then except back in the car. And thanks for letting us know it's a convertible. I don't have one, but suspect there are other possible sources of water getting in with a convertible. I'm out.
Old 08 Jun 2019, 12:28 pm
rob302's Avatar
Have you had the windshield replaced? How does a plastic wiper cowl panel that covers the cabin filter look against the windshield? Perfectly? I seem to remember someone else there and having to silicone things to fix your issue..
I'm assuming you are smart and accurate in saying that this is after heavy rain, and it's not from a clogged AC core drain tube
You could always bust out a pressure washer and try to duplicate it.
Water leaking onto floorboard drivers side JolieCruiser General PT Cruiser Discussions 22 25 Jul 2015 07:48 pm
Water leaking ceil99 Tech & Performance Forum 5 24 May 2015 12:47 pm
Water leaking from the bottom micdhack General PT Cruiser Discussions 8 02 Jun 2014 07:26 pm
Water pump leaking at 38,000, have a question... Rumble Tech & Performance Forum 8 30 Dec 2008 07:12 pm
water leaking six0fourgirl Tech & Performance Forum 18 02 Oct 2008 09:51 am
