PROJECT: PT Crawler Convertible Build
Like Tree94Likes
  #41 (permalink)
Old 12 May 2020, 01:18 pm
soonercruiser's Avatar
Default Re: PROJECT: PT Crawler Convertible Build
Originally Posted by 917K View Post
Looking good TP, all that engineering required to make this project work would do my head in, but it will be one cool ride when it's done! We're looking forward to the next post.
Ditto here!
My head has been spinning!
Frank, aka SOONERCRUISER,
  #42 (permalink)
Old 12 May 2020, 07:06 pm
tpcroozer's Avatar
Thanks guys, I appreciate the encouragement... With COVID19 happening and work hours shortened a little, I've managed at least a full day each week to devote to this project and it has helped with the progress.
PS: I'm coming up on lots of sheetmetal welding. So far, my welding is
  #43 (permalink)
Old 19 May 2020, 12:15 am
tpcroozer's Avatar
I have the firewall welded in place and the front inner fenders are welded in too. The area below the front arched supports where I originally cut it out has now been welded back in place. I also welded back in place the radiator supports for both the PT Cruiser or the original Sidekick in case I start out using the original Sidekick on instead of waiting and fabbing up the connections for the PT Fan and radiator (I still want to do this but may wait a bit until it is driveable). My welding is still apprentice level but everything seems to have a good bond but just isn't pretty. I'm just cutting up scraps of old body parts to connect things together. This is a true reflection of a beginner's DIY low budget build!
After getting front fenders and both bumpers in place I discovered that I need to move the body forward 1/2". Ugh... Oh well, I guess this was to be expected. I'm going to have rubbing issues in the front on both sides of the wheel. The little waffle piece behind the plastic inner fender will need some massaging and the plastic front bumper is going to have to have about an inch ground off behind the leading edge. The goal is still to make it work without chopping any of the fenders' outside body edges. The rear wheel will go backward about 1/2". This will give it 1.5" in front of the rear wheel and 2.5" behind. This should be about right since the trailing arms rotate up and back during the compression of the rear end and wheels.
Handy_Cruiser likes this.
  #44 (permalink)
Old 19 May 2020, 12:20 am
tpcroozer's Avatar
This photo is behind the front wheel before the body gets moved forward 1/2" on the frame.
Handy_Cruiser and Royal like this.
Handy's New Turbo Convertible PT Project! Handy_Cruiser Members PT Project 631 24 May 2020 12:47 pm
Project Control Arm AKA Project Lost Cause Birdman Wheels, Tires, Suspension 9 31 Oct 2017 10:48 am
'05 GT convertible build GtPt05 Members PT Project 55 17 Jul 2017 09:10 am
NJSTEVEs 05 GT Convertible Build History njsteve1 Members PT Project 11 03 Apr 2014 01:14 pm
Factory Hold on GT Convertible Build???? MACE PT Cruiser Convertible Forum 0 20 Apr 2004 12:56 am
