Window problems
  #21 (permalink)
Old 26 Feb 2017, 11:29 am
Default Re: Window problems
Hi ... I have an 06 convertible. All window and top operations are normal with one exception. The passenger window will not auto drop. I have tried all the reset procedures and nothing seems to work. There is some residual glass inside the door from a broken window and the plastic between the door panel and the door is cut up. So I know someone did replace the window. I also found the upper limit stop to be out of adjustment. Took me a minute to find that little bugger. That is now adjusted. But still can't seem to reset/revive the auto drop. Im thinking I am going to have to bite the bullet and get it hooked up to a DRBIII... I just don't trust mechanics. I'm worried they are going to try and sell me a new module when all that may need to be done is a re-flash...
  #22 (permalink)
Old 26 Feb 2017, 09:33 pm
What have you done so far to reset the glass module?
Window Problems in cold weather franski PT Cruiser Convertible Forum 3 31 Dec 2012 09:08 pm
Oval WIndow Completion judpma General PT Cruiser Discussions 0 18 Aug 2005 02:01 pm
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
Weird hatch window replacement problem! SRG Tech & Performance Forum 6 20 Jan 2005 01:39 am
Leaky rear window washer Jimbo General PT Cruiser Discussions 2 02 May 2004 09:33 am
