PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors
Dashboard Complaints
  #31 (permalink)
Old 27 Mar 2008, 12:46 am
careyk careyk is offline
Default Re: Dashboard Complaints
Hey Mean Green...I guess the 3 Pts you and your wife have have OK dashes because you must be taking CREWZIN's advice and using the back seat on all three...ha ha ha:rolleye s:
]2003 PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door speers, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,new Falcon tires, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover
  #32 (permalink)
Old 08 Apr 2008, 08:36 am
Howell53 Howell53 is offline
I have a 2002, and a few months ago I noticed the dash cracked from the middle dash vent forward to the windshield, from both sides of the vent. Now it also has a crack from the middle of the vent to the front of the dash. and it has been garaged! I found a source to buy a replacement, but I did not see any replies to the question of how to remove the old dash. Anybody???
  #33 (permalink)
Old 08 Apr 2008, 09:28 am
SRG SRG is offline
How to take the dash cover off (up to 2005 models only):
1. Pull the 4 ac knobs off (protecf them with a cloth if you need pliers to do this).
2. Pry the power window switch assembly out of the dash, carefull of damaging the dash. It should just pop out. Then you must remove the cable by sliding the lock tab thingy (on the passenger's side of the switch I believe) and hold down the release, then pull off. Put switch aside.
3. Look inside the hole where the switch was, you'll see a phillips head screw, this holds the center console cover in place. Remove screw. gently grab the edge of the switch hole and pull. The entire cover is held in by clips, work your way around the cover until its off.
4. There are 2 phillip head screws now showing to either side of where the first phillips screw was, remove them.
5. Carefully pry the A-pillar covers off both sides of the dashboard. Like most of the trim in the car, they are held in place with metal clips.
6. The dash cover is now held in place by clips across the edge of the dashboard closest to you. Start at one side, grabbing the exposed edges, pull up and unsnap the clips. Haveing 2 people doing this together make it a LOT easier. When the back side of the dash is up, pull dash cover towards you, this will disengage the hooks that hold the front of the dash cover in place.
Install is the exact reverse of these instructions. A helper would make things a lot easier.
You'll notice that metal clips play a large part in the assembly of the trim of the PT. Be careful not to lose any as sometimes they fall out of the part. Just slide back in place.
Sorry to be so long, but it is very easy and a crime to have to pay a dealer (or anyone) to do it!!!
srg
  #34 (permalink)
Old 08 Apr 2008, 02:39 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Cool Re: Dashboard Complaints
A 2002....and thinking of replacing the dash cover because of a crack; that is otherwise not a structral problem (cosmetic only)?????
I'd do a dash mat myself. I start from the beginning with one, as a preventive measure. If in the hot sun a lot, use a full window shield/visor.
**But, if you want to be creative....
(picture to come tonight!)
  #35 (permalink)
Old 08 Apr 2008, 02:42 pm
This is great, very detailed directions. Thank you very much!!
srg
  #36 (permalink)
Old 08 Apr 2008, 06:38 pm
SRG SRG is offline
Yes, the dash cover that sits on top of the dashboard of 2001 to 05 is only a cover, I doubt it has any structural value at all.
srg
  #37 (permalink)
Old 08 Apr 2008, 09:45 pm
The Preventive Measure....my custom dash mat!
PT Cruiser World
vB code is On
Feds Investigate Land Rover Driveshaft Complaints, PT Cruiser ... - Edmunds.com/Insid skylight PT Cruiser News and Rumors 5 16 Apr 2007 09:56 am
Rattle/squeek in dashboard robinjoe General PT Cruiser Discussions 1 05 Apr 2007 10:24 am
Annoying squeek in dashboard robinjoe Interior Accessories Forum 3 30 Mar 2007 10:06 pm
Dashboard Rattle Shini Quiet General PT Cruiser Discussions 4 16 May 2005 09:03 am
Navigation on dashboard 2004 dinarose Interior Accessories Forum 9 07 Oct 2003 12:35 am
  Modded Xbox | Mortgage Loans | Loans | Cute Dogs | Credit Counseling
