Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors
Power steering
Old 10 Nov 2012, 05:34 pm
Exclamation Power steering
What type of solvent or cleaner is good to use to clean out the clogged reservoir.
Old 10 Nov 2012, 06:38 pm
Default Re: Power steering
You can use engine cleaner, carb cleaner,and kerosene. To name a few.
Old 10 Nov 2012, 10:21 pm
Thanks appreciate it
Old 21 Jan 2013, 01:31 pm
a_bartle's Avatar
How difficult is it to pull the reservoir tank out for cleaning? I'd like to do the same thing, my daughters car is making the famous "groaning" noise. It's a regular, base model 2001, so I'm not sure if I have regular power steering fluid or ATF+4, but I figured I'll switch to ATF+4 after I clean out the reservoir (and try to flush out as much of the old as possible). However, did Chrysler change the filter design on later models when they changed over to ATF? Will the ATF clog the filter any sooner than the regular clear power steering fluid?
Also, has anyone considered removing the screen (I know it's not a "removable" screen, but couldn't a person just break the screen out or punch a hole in it?) in the reservoir and going with an "in-line" filter (they list them at AutoZone)??
Thanks...
Art
Old 29 Jan 2013, 09:43 am
I have a 2001 PT and had the same grinding noise that seemed to be the power steering as well. I took it to my mechanic who is the absolute best mechanic I have ever used and he said it was the rack n pinion. I had it replaced and all is well. He said PT's are notorious for this. Do your own research with that in mind.
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
power steering? PTcruzer02 Tech & Performance Forum 7 25 Feb 2012 11:39 am
Power Steering ? reklaweelmada Tech & Performance Forum 5 24 Dec 2009 08:08 pm
no power steering rsr02 General PT Cruiser Discussions 1 29 Nov 2009 12:36 am
Power Steering proxeyed Tech & Performance Forum 6 02 Mar 2005 09:55 pm
