Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors
clocksping, save me
Like Tree2Likes
Old 17 Dec 2012, 03:10 pm
Default clocksping, save me
oh guys seriously i was try to unluck the air bag from steering for 1hour
and didnt knew how to do it
am trying to reach to clockspring
why ? bcuz i have the airbag light on,no horn=clockspring problem
some times when i spin the steering the horn works
so is there any description how to open this thing out ?
sorry for bad engliiiiiiish
Old 17 Dec 2012, 03:17 pm
Default Re: clocksping, save me
AIR BAG REMOVAL
(1) Open hood.
(2) Disconnect and isolate the battery negative cable.
(3) Wait two minutes for the system reserve capacitor to discharge before servicing any airbag components.
(4) Remove upper and lower steering column shrouds to gain access to clock spring wiring
(5) Using a pair of 90 internal snap ring pliers or equivalent, pry open the retaining clip on the back of the steering wheel to release the retaining pin Pull or press rearward (toward driver) on the driver airbag while doing this. The pin will release slightly.
(6) Using a pair of 90 internal snap ring pliers or equivalent, pry open the retaining clip and at the same time gently pry the pin away from the retaining clip, using a pocket screwdriver or equivalent, so it can slide through the middle of the clip. Use the screwdriver to push the pin through the clip.
(7) When the driver airbag releases from the steering wheel, peel rearward and expose the underside of the airbag. Disconnect the two harness connectors, squib and horn feed. Use a small pocket screwdriver to separate horn connector. Insert into the bottom of the connector (airbag side)
and pull handle of screwdriver up while pulling out on the clock spring side of the connector.
(8) Remove airbag from vehicle.
CLOCKSPRING REMOVAL
(1) Place the front road wheels in the straight ahead position. Then:
Rotate the steering wheel half turn (180 degrees) to the right (clockwise).
Lock column with ignition lock cylinder.
(5) Remove steering wheel.
(6) Remove upper and lower steering column
shrouds to gain access to clock spring wiring.
(7) Remove multi-function switch.
(8) Disconnect the 7-way connector between the clock spring and the instrument panel wiring harness at the base of the clock spring.
(9) Remove clock spring by lifting the top latch tab up slightly to guide it over the lock housing.
The clock spring cannot be repaired, and must be replaced if faulty.
Last edited by sanatanadharma; 17 Dec 2012 at 03:24 pm. Reason: Edited to add clockspring removal steps.
Old 17 Dec 2012, 03:22 pm
cruserdad1976's Avatar
good one santanananbut is that how you get to the clockspriung????
Old 17 Dec 2012, 03:24 pm
Just edited to add clockspring removal steps.
Old 17 Dec 2012, 03:44 pm
you da man
Old 17 Dec 2012, 03:58 pm
Ray_Dockrey's Avatar
Here are the instructions for installing aftermarket cruise control. In the instructions it shows how to get the airbag off and the clock spring. Thought this might be helpful as there are pictures showing what you are trying to accomplish with the air bag clips. This is for 01-05.
http://www.moparsupercenter.com/pdfs/82208198.pdf
Old 17 Dec 2012, 04:36 pm
thanks guys
Old 17 Dec 2012, 05:55 pm
but i really didnt get the step #6 airbag removal
Old 17 Dec 2012, 06:28 pm
Look at the pictures;
Old 21 Dec 2012, 02:17 pm
mdskinner731's Avatar
i kno in my moms pt, some times there is no horn and no dash lights.
some times dash lights and no horn
and horn works and but has no dash lights. i've narrowed it down to the main wiring connector that goes to the steering column.
if i wiggle it or tap the bottom of the steering wheel hard they both work!
bhour likes this.
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Help me save my PT pkpt04 Tech & Performance Forum 4 10 Jan 2010 04:54 pm
FS: Quaiffe LSD Save 66% off new! MINIHEMI148 Classifieds: For Sale/Trade 0 03 May 2008 08:31 pm
Save $$$? Mel K Stage Turbo Kits 3 09 Sep 2003 08:32 am
