Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors
2004 Touring bucks while idling
Old 03 Nov 2013, 07:09 am
Default 2004 Touring bucks while idling
I bought an 04 with 93K miles at an auction for $1,900. Came with a P0172 code and bucked when idling. Replaced a bunch of stuff including:
ABS Absorber
Water Pump
Tensioner
MAP sensor
PCV Valve
Thermostat
Air filter
Both 02 sensors
Got a tune up (including plugs & wires) and coolant flush.
Still bucks badly, and seems to be getting worse. Code 0172. Plus there is an exhaust smell in the car while driving.
Took it to a new mechanic who said it was not timed right when the PCV valve was replaced. Off by 1/2 tooth. He'd charge $790 labor to get it back in time. This mechanic comes with good references from a local auto parts store (they use him exclusively for their vehicles). He charged nothing to check.
Took it back to the mechanic who changed the PCV valve. He said it wouldn't even run if it was out of time. He said he was sure it was timed right. But he did say when he put on the PCV valve (or something) he saw the timing belt had been replaced. He charged $20 and said he did a compression check that showed it needed a valve job ($1,690). He said the prior owner probably experienced a timing belt break that ruined the valves. Now I read on here that my car has a non-interface engine and valves don't get ruined by timing belt breaks.
I am at my wits end and don't know what to do or who to believe. I don' have much money left and want to fix what's really wrong or just try to get rid of a car that bucks. I won't get any of my $2,800 back.
What to do? Does anyone have a PT mechanic in Hampton Roads VA? I have thought of taking it to a Chrysler dealer to find out exactly what is wrong. ANY help is appreciated!
~C
Old 03 Nov 2013, 08:17 am
Default Re: 2004 Touring bucks while idling
...about the timing belt. YES, it's a non-interference engine which means when the belt breaks, the valves can't hit the piston tops and cause major internal damage BUT if the engine happens to be at high speed when the belt broke, the free wheeling opposing valves can hit each other. It doesn't happen but about 1% of the time in fact I think we've only heard of the valves hitting in one or two cases out of hundreds that have come to the forum.
Busted_PT likes this.
Old 03 Nov 2013, 03:48 pm
randyincctx's Avatar
Cool Re: 2004 Touring bucks while idling
Sorry to hear your having so many problems with your 'auction' PT.......I also got my PT from an auction,but so far most of my problems were cosmetic;I did have to replace the battery,and use some starter fluid,to get it fired up after sitting for a year in impound,before the auction.
Aka:~KILLER~
Old 03 Nov 2013, 06:39 pm
PTpreacher's Avatar
Smile Re: 2004 Touring bucks while idling
Did you check the cat? the exhaust smell makes me think to check it. I had a car that had one plugged.
And it also got hot and had a smell. Worth a check!
PTpreacher
Old 03 Nov 2013, 07:35 pm
Thanks for the responses. Will check the things you suggest. I am SO thankful for this forum!
~C
Old 03 Nov 2013, 07:45 pm
ABS Absorber
Water Pump
Tensioner
MAP sensor
PCV Valve
Thermostat
Air filter
Both 02 sensors
~C
You said you replaced water pump. That is driven by the timing belt. So if the timing is off. That's when it happened. You can't get it off by 1/2 tooth. Just is not physically possible. So run from that guy. You can only get off one full tooth at a time. Yes they will run. Just not well. So, unimpressed by either these guys.
Old 03 Nov 2013, 11:38 pm
Post Re: 2004 Touring bucks while idling
That's where I'd put my money down.....Whoever did the water pump & tensioner replacement,got the timing belt off......I think you should take it back to them,and tell them to double check it;Might not hurt to print this page,and show it to them.
If it's correct,it should look exactly like the photos below.
Originally Posted by randyincctx View Post
Even leaving everything in place,there is still room for error when installing a new belt.....It can end up off when you tighten the new belt,and if your off by even ONE tooth/notch,it can cause it to be out of timing(even seasoned auto-techs get it wrong)......The best pictures we have on alignment for the timing belt install are these right here:
Everything needs to be lined up EXACTLY as seen in these photos.Photos courtesy of Busted_PT
Aka:~KILLER~
Old 17 Nov 2013, 06:29 am
Thanks for all this great information! I have reviewed all posts/suggestions. Also took it to a Chrysler dealer who performed some diagnostics. His response: "Turbo assy cracked. $2K to fix - not worth it."
Does anyone agree? Other opinions? I have considered replacing the engine. How does one go about getting someone to do that?
Thanks for all suggestions.
Connie
Old 17 Nov 2013, 11:09 am
Turbo doesn't cost that much - try Turbos Unleashed
Old 17 Nov 2013, 02:09 pm
Lightbulb Re: 2004 Touring bucks while idling
1st mistake.....
Check local salvage yards,or online rebuilt/used/salvage(Ebay!)......Even if the used turbo assy needs to be rebuilt,it will be alot less than $2k.(What did you expect a 'Stealership' to say?)
-Not 100% sure if it's the same;But,you might take a look at this one(Rebuilt Neon/PT Cruiser Turbo-'$100 Discount w/rebuildable core')=$450+$28.28 s/h:Neon SRT 4 PT Cruiser GT TD04LR Turbo 03 05 Stock Factory turbocharger SRT4 | eBay
Aka:~KILLER~
Like new very low mil 2004 Touring for sale Rolf Classifieds: For Sale/Trade 1 05 Sep 2012 08:33 pm
2004 Turbo Touring Maintenance Questions firemedic1560 Turbo Wheels/Suspension/Handling 9 05 Mar 2012 12:09 pm
2004 pt cruiser turbo touring srl123 General Turbo Discussions 15 17 Feb 2012 11:01 am
2004 PT Touring Turbo parts FS InfernoPT Classifieds: For Sale/Trade 3 06 Oct 2009 08:09 am
2004 PT Touring Edition PTCumming Tech & Performance Forum 11 14 Oct 2003 10:36 pm
