2006 pt cruiser base, we did the head and timing belt last year
Now is having a problem and I can find the solution, I need help!! car sounds horrible and idles bad 500 to 1500 rpm's jumping up and down all the time if I drive it runs ok but don't have too much power a new manifold pressure sensor, pvc valve, vacuum connector from the brake booster was installed still the same problem I replaced the intake and throttle body from the junkyard, still same problem I can't find the leak, what else can I check? thank you
2008 Pt cruiser Touring 2004 Pt Cruiser GT 2004 Chrysler 300M 2008 Chrysler Pacifica awd |
I am posting a post that you posted a while back. I would appreciate if you would post the pictures. Thanks
If at First You Don't Succeed - Try, Try Again |
Do you have a base model or GT?
You had a previous thread from last year that you were looking for a PCM for a GT: Want to buy an ecu computer 2006 GT Did you ever replace the PCM? You can get a remanufactured one on Ebay if you still need one.
![]() ![]() '06 Touring Edition NA Automatic 163k Miles / Electric Blue Pearl USMC '82 - '93 |
P0274 = Manifold Pressure / Throttle Position Correlation; High Flow & Vacuum Leak
Possible Causes: 1. Vacuum leak in hoses or component connections 2. High resistance or resistance to ground in MAP 5 volt supply or signal circuit 3. MAP Sensor has failed 4. High resistance in MAP ground circuit 5. Throttle Position Sensor has failed or is improperly adjusted 6. High resistance or resistance to ground in Throttle Position Sensor 5 volt supply or signal circuit 7. High resistance in Throttle Position Sensor ground circuit 8. PCM has failed Check all the hoses. 1. Inspect the Intake Manifold for leaks and cracks. 2. Inspect the Power Brake Booster for any vacuum leaks. 3. Inspect the PCV system for proper operation or any vacuum leaks. 4. Check all hoses on the turbo.
base pt cruiser.
I have to look for my old phone, I have an extra TIPM if you need one
![]() Quote:
![]() Quote:
Sending PM ![]()
![]() Quote:
Almost everything was replaced, Throttle body with sensor and plastic intake map sensor, cam sensor, I took all the engine mounts to see the timing belt and it's almost perfect, the intake cam is move half of a tooth but if I fix it, it will be half of a tooth the other way, I have done about 6 timing belts and sometimes they are not perfect, once In a different vehicle I was 1 tooth out and it run perfectly, I know timing belt is not the problem. this car drives ok, but it's weak and it idles bad, my next option is the computer but I have to replace it without been 100% sure that the problem is there, i need to find a way to test it
I would suggest using a vacuum gauge for reading, if the belt is off a tooth it will reflect in either a very high idle HG or very low. An engine that is in good condition will idle between 16-18 steady on most 2.4 engines. Post what you find.
Thread Tools | |
Display Modes | |
ERROR CODE P2074 | spinner | Tech & Performance Forum | 5 | 30 Jul 2016 06:00 pm |
P2074 & P0123 After replacing TPS & MAP | Davejay | General PT Cruiser Discussions | 1 | 06 Sep 2013 05:30 pm |
P2074 Error, Cause and Resolution | mriggins | General PT Cruiser Discussions | 3 | 21 May 2013 07:20 am |
Manifold pressure sensor problem and misfiring | Binny | Tech & Performance Forum | 1 | 08 Feb 2012 02:41 pm |
code p2074 | interrex | General PT Cruiser Discussions | 8 | 08 Sep 2011 03:37 pm |
