Go Back   PT Cruiser Forum > General Forums > PT Cruiser News and Rumors
No Power From Alternator After Trans Swap
Like Tree7Likes
  #11 (permalink)
Old 07 Aug 2017, 01:06 pm
Default Re: No Power From Alternator After Trans Swap
Alternators fail slowly - little warning that it is doing so ..
As an experiment, try giving the alt. a sharp rap (applies to motors in general), it may then return to life for a short time .. I'd love to see automobiles with sufficient gages (oil pressure and battery condition(volts)) .
VsandFords likes this.
  #12 (permalink)
Old 07 Aug 2017, 02:15 pm
VsandFords's Avatar
I agree.
  #13 (permalink)
Old 07 Aug 2017, 08:41 pm
rckstein's Avatar
Originally Posted by VsandFords View Post
I agree.
UltraGauge can give you the alternator info, too
  #14 (permalink)
Old 07 Aug 2017, 09:08 pm
Check to see what the battery voltage is at 2000 rpm. Make sure battery is fully charged and is at or above 12.5 volts with the ignition off.
  #15 (permalink)
Old 10 Aug 2017, 09:19 pm
Flash619's Avatar
Thank you all for your help!
I didn't have the green wire attached to the starter. Guess I went too quick and overlooked it.
rckstein likes this.
  #16 (permalink)
Old 10 Aug 2017, 11:13 pm
Thanks for coming back and posting what the problem was. Glad you got it fixed.
JDK52 likes this.
Tags
alternator, dead, power, test, transmission
Engine and trans swap help Poshane General PT Cruiser Discussions 6 27 Aug 2016 10:20 pm
5 speed trans swap?? drumrooster Tech & Performance Forum 0 30 May 2014 11:01 pm
Neon PT 5 speed trans swap?? drumrooster Tech & Performance Forum 3 30 Apr 2014 05:23 pm
Engine/Trans swap thebanjo69 General PT Cruiser Discussions 5 08 Jul 2012 12:31 am
