PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   PT Cruiser Videos (http://www.ptcruiserlinks.com/forum/pt-cruiser-videos/)
-   -   Please help temp. Selector/vent (http://www.ptcruiserlinks.com/forum/pt-cruiser-videos/62016-please-help-temp-selector-vent.html)
Mh12738 20 Nov 2016 04:29 am
I have 06. The temp control n vent selector is not working. I need help maybe a video how to get vent open for the winter. Also no heat... new fan and thermostat already. Blend valve. What to try next ? Mhunter12738@gmail.com
chuzz 20 Nov 2016 06:50 am
Re: Please help temp. Selector/vent
I'm not sure how the second gen heat is controlled, but on my 03, it's a cable. You have to remove the center plastic cover around the radio and heat controls in order to access it. The first thing you need to do is to make sure you have enough anti-freeze in the radiator and overflow.
CREWZIN 20 Nov 2016 08:04 am
As was already said, the first generation might be different but here's how that looks.....
http://img.photobucket.com/albums/v7...otos/HVAC2.jpg
JoeX 20 Nov 2016 12:01 pm
The redesigned Second generation Cruisers have twisted strand cable that tend to kink behind the knobs. I straightened mine and if I'm gentle with the controls they keep working instead of bending
wingman55 20 Nov 2016 12:08 pm
1 Attachment(s)
HI. I also have an '06. The main cover on the dash just unsnaps BUT you need to remove two screws in the centers of the vents first.
Here is a photo from my Field Service Manual. For some reason removing the screws was left out. I discovered that fact when looking at a stereo replacement guide, and it mentioned the two screws.
Attachment 19276
I re-installed the cover without re-installing the two screws and it's just fine.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
