Go Back   PT Cruiser Forum > General Forums > PT Cruiser Videos
2005 PT cruiser, 120,000 miles/ crank no start
Old 23 Jan 2017, 08:38 pm
Default 2005 PT cruiser, 120,000 miles/ crank no start
I was driving to work going about 70 and PT dies, no sounds, just dies and slows down. check engine light was on while driving, code p0462, fuel level sensor curict low, would crank but wouldn't start. changed fuel pump about 5 months ago, thought that was the problem again. changed the fuel pump and will crank and run for a few seconds and then dies. had the timing belt replaced at 105,000 spark plugs, wires and high performance cool at 80,000. check engine light is no longer on but still won't start, but canks. i used starting fluid to try and start it but it started detonating. not sure what could be the problem. any inputs are greatly appreciated. pt actually only has (112,000) miles, wouldn't let me edit the title
Old 23 Jan 2017, 09:24 pm
Default Re: 2005 PT cruiser, 120,000 miles/ crank no start
I am suggesting you check the engine compression. This will give us some ideas of where to take it from there.
Also check the wires going to your crankshaft and camshaft sensors.
Old 24 Jan 2017, 06:13 am
_PTGT03's Avatar
have you though about doing a fuel pressure check ?
after your fuel pressure and ingition system (and timing)
the other very plausible cause is an activation of vehicle anti-theft or a defective PCM.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 12 Mar 2017, 06:20 pm
What about that Relay in the fuse box. I recall having the PT just die for no reason and after thinking I'd lost my mind, learned about the main engine compartment fuse box and how one of those Omeron relays can shut the PT Down ?? It's inside the air cleaner cover is labeled as to which one handles fuel injection
Old 12 Mar 2017, 07:55 pm
VsandFords's Avatar
Welcome to the forum from Texas. When you have a sec, go to new members and introduce yourself.
Old 18 Mar 2017, 12:30 pm
I think you are referring to the ASD relay. Automatic Shut Down and yes it can exhibit those symptoms. Swap it with the A/C compressor relay (they are same exact relay). See if problem stops. Failing crank pos or cam pos sensor can do same thing. Sometimes no codes. Very common problem on Jeep Grand Cherokee I used to have. Similar symptoms.
Old 07 May 2017, 05:03 pm
At around 150K miles I renewed the crank position sensor as part of PM ..same with the fuel pump - and I hope that the Cruiser has an access hole ...
Anyway , this PM yields 100% vehicular reliability ... but , at 190K, the oil lite stayed on .. the end ...
2005 2.4l no crank, no start. Need help!!!!! wayne272 Tech & Performance Forum 8 16 Aug 2016 12:01 pm
PT Cruiser won't crank / start mgreenb561 Tech & Performance Forum 22 29 Mar 2016 09:49 am
2005 cruiser won't crank to start OJR Tech & Performance Forum 17 12 Dec 2015 04:28 pm
04 pt cruiser no crank no start vwnmustang Tech & Performance Forum 10 18 Aug 2015 10:20 am
2005 turbo/auto, 80K miles, shuts off immediately after cold start TheDarkSideofWill Tech & Performance Forum 8 26 Oct 2012 04:31 pm
