Go Back   PT Cruiser Forum > General Forums > PT Cruiser Videos
installing daytime running lights
Like Tree3Likes
Old 02 Apr 2017, 10:33 pm
Question installing daytime running lights
I have just purchased a 2007 PT Cruiser in California and imported into Canada (have to have daytime running lights) how do I manage to get this done as nowhere does it show weather it has a flasher unit of a module ?
Old 03 Apr 2017, 01:01 am
LionPT's Avatar
Default Re: installing daytime running lights
No flasher relay in the G2's 2006-2010. It all controlled by the PCM.
Nexus 5X, Nexus 4, Nexus 7 (2013)
Old 03 Apr 2017, 05:01 am
I used WEB ELECTRICS for adding the flashing 3rd brake lights on all my cars. They also do a universal DRL kit. Take a look at their site....
WebElectric Products - Sequential Turn Signals, Sequential Taillights, Sequential Tail Lights, Dynamite Stick Sequential, Pulsing Brake Light Pulser Flasher, One Touch Convertible Top, Dynamite Stick, One Touch Turn Signals, Daytime Running Lights, L
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 03 Apr 2017, 02:59 pm
rckstein's Avatar
Originally Posted by CREWZIN View Post
I sent an email to WebElectric to inquire if their Daytime Running Light Module DRL-1 would work on the Gen2 PT with the CANbus electrical system. This is the reply I received from their technical support dept:
"I don't think so. I believe a CAN bus always checks to see if the device is
connected. When the DRLs are on, the bulbs are disconnected from the
original harness. If the CAN bus is looking for light bulbs, it won't find
them and may issue a fault.
Try this. Pull out your turn signal bulbs. Do not turn the signal on, just
start the car. See if you get a fault.
-L
http://www.webelectricproducts.com/products.htm"
'06 Touring Edition NA Automatic
157k Miles / Electric Blue Pearl
USMC '82 - '93
Old 03 Apr 2017, 05:36 pm
It was worth a try. BTW, did you try their suggestion and did you get a fault light?
Old 03 Apr 2017, 08:18 pm
rckstein's Avatar
No I did not, the OP can try it on his PT, if he wants to.
USMC '82 - '93
Old 03 Apr 2017, 10:44 pm
_PTGT03's Avatar
Just so you know, you jumper an accessory fuse to the left and right headlight fuse.
It only takes a piece of wire.
But, I have a suspicion this is just a hit and run post by the OP
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 04 Apr 2017, 12:18 am
rckstein's Avatar
You have a Gen1 and the OP has a Gen2, will what you have explained work on a Gen2?
USMC '82 - '93
Old 11 Apr 2017, 06:04 am
I think you need to go to the dealer, or someone with a Starscan, or similar Chrysler tool, and turn on the DRL in the appropriate module. I watched a youtube video showing the steps for a challenger or charger. It is likely the same for the PT Cruiser.
Old 11 Apr 2017, 08:05 am
Challenger and charger are not the same as the PT. There is no module to enable DLR. Technically on the U.S. PT's the first rotation point forward that turns on the front marker bulbs is the DLR. The DLR he is looking for canada (i'd assume) is a more traditional DLR that switches the high beam lights in series for a low output light. There is no such system on normal U.S. PT cruisers.
03' Dream Cruiser Manual: 119k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback.
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Daytime Running Lights... LionPT General PT Cruiser Discussions 10 09 Feb 2017 05:18 pm
Daytime running lights? ClovisMan Tech & Performance Forum 7 09 Feb 2017 05:16 pm
Daytime running lights won't turn off! kbaum07 Tech & Performance Forum 4 06 Apr 2014 05:02 pm
Daytime Running Lights SteveANJ General PT Cruiser Discussions 6 05 Mar 2008 09:38 am
Daytime Running Lights Jay M Exterior Accessories Forum 0 14 Sep 2001 08:18 pm
