front door panel speaker size?
Old 16 Feb 2006, 04:50 am
Default front door panel speaker size?
what size speakers fit in the front doors? I need to replace them soon thanks I want something with a little more power
O maybe also the back too what is the size?
Old 16 Feb 2006, 10:53 am
in the front you have 6 1/2 speakers in the door, but you should buy a compent set with the tweeter and speaker, plenty of room to put the crossover in the door
03, onyx 5 speed, custom interior, 14 tv\'s, ps2, , custom stereo, hood, bruiser front, sides, roll pan, custom exhaust,20 inch rims, air ride system, 4 12inch subs in a molded in a box, member of del val and GROUNDED 4 LIFE. vertical doors, big ass ragtop roof, 10.5 inch screen in steering wheel, move window switches to glove box, glassed a tv where the switches were, smoothed dash and painted, led tailights, tv;s in quater panel windows
FRESH TWO TONE GREEN AND SILVER , SHAVED TAILIGHTS WITH LEDS IN THE ROLL PAN...
Old 16 Feb 2006, 12:08 pm
The rear speakers are 6x9 if you plan on replacing those too.
Old 16 Feb 2006, 01:58 pm
If you are looking for direct replacement in the first generation the best fit for direct replacement without the use of adapters I believe is
Front 6 3/4"
Back 5x7
You can fit a 6 1/2" in the doors but most will require an adapter plate to fit.
And i dont think that you can fit a 6x9 in the rear. It barely has enough room for the 5x7.
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown.
Carl Sagan (1934 - 1996)
Old 16 Feb 2006, 03:01 pm
the rears are 5x7 , and thats a snug fit..no way 6x9's i just replaced the rears and front speakers . 6 1/2 and 5x7
Old 16 Feb 2006, 05:49 pm
Check out the 'Find What Fits My Car' tool at the Crutchfield website
http://www.crutchfield.com/S-Imx7FFX...*ctzfubflFYgzy
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 17 Feb 2006, 02:22 pm
Sorry, I'm bad. You're right, 5x7. I was guessing for the rear size. It's been so long since I changed them out. Could not remember.
Old 19 Feb 2006, 02:07 am
When I changed mine out... I got an adapter but it still did not fit right... I had to trim out part of the plastic AND part of the door to get it to fit right. And plan on having a drill on standby because I am almost sure the stock speakers have 3 hole mounts, and any replacements will have 4. No biggie though.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 20 Feb 2006, 06:07 am
thanks what about the small twiters in in the dash? ...does replacing thee speakers make sound better?
Old 22 Feb 2006, 07:33 am
sorry for the late response...
in short... after getting my new speakers WITH tweeters built in... I noticed an incredible performance increase in sound over stock.
Changing out tweeters would probably not do much difference to the overall sound quality. Probably placement of the tweeters would do the most good. With one 12" kicker in the back, the tweeters built in the speakers with that of the dash as well do the trick. Before I moved from stock speakers (no tweeters) just using dash... huge crap when listening to anything with bass and high's while sub is goin off. Sounded like the high's were drowning in a pool of mud.
All fixed now
BTW my speakers are polk db 570's at the back and 675's for the front. These are NOT component sets... but I didn't need them. They do have component sets of these though... check out crutchfield.com
After replacing all 4 speaker + what I think after Ctown Sound and Security Forum 20 22 Mar 2008 07:11 am
Speaker count and size rush123ed Sound and Security Forum 2 02 Apr 2007 07:57 am
correct speaker wire harness for front speakers Curruzr General PT Cruiser Discussions 4 12 Aug 2004 04:01 pm
Sway bar size front and rear AlmondTurbo Turbo Wheels/Suspension/Handling 0 28 Jun 2004 02:15 pm
Front Door Speaker Dimensions? yobiebs Sound and Security Forum 5 23 May 2003 01:07 pm
