Want to replace the tweeter too what size?
Old 18 Mar 2006, 05:45 am
Default Want to replace the tweeter too what size?
Guys whats a good size for replacing the stock tweeter? Are they worth changing and how much work do I need to change them?
I'm getting a Sub as u know and will they really make a different?
Old 20 Mar 2006, 01:42 am
Why don't you change out the speakers to ones that have built in tweeters? That will make a bigger difference than just the stock tweeters being changed out.
*EDIT*
ROFL didn't bother reading other posts today :P Ok so you already have your speakers... you could change out the stock tweeters to 3/4" or so. As for the brand, I couldn't tell you what the best tweeter would be out there since I haven't really had to change mine out (only added) so as for a difference, it would help probably for clarity... but keep in mind you could also just "add" some tweeters to the middle pillars in the car on both sides since you have a sub, this way you can also aim them where you want.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 27 Mar 2006, 02:30 am
I took out the OEM tweeters The they look like something you would find in your keyboard or casio calculator. I got some 3.5 inch replacement and since the OEMs have NO depth any type of new tweeter around the size of 3.5" you will find yourself cutting away the dash. Cutting takes alot of time. The best way to cut the hold is to use a drill it will look messy but with the glass in the way it's the only way and even if it does look messy no one can see it after u put the top dash back But it was really a pain in the ass I think u may not want to replace them since if u do u'll find that the sound coming from the dash will filter out the door speaker....as for me I love it
Cat size KingKole02 Tech & Performance Forum 4 21 Mar 2006 01:54 pm
front door panel speaker size? Ctown Sound and Security Forum 11 17 Mar 2006 06:50 pm
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
