XM Radio Antenna
Old 25 May 2003, 02:25 am
Default XM Radio Antenna
I’m thinking about adding XM radio to my cruiser but would like some suggestions on the placement of the antenna. I don’t like the hockey puck antenna; I would prefer a glass mount on the side rear window. Has anyone done this and which antenna did you use.
Thanks
Old 25 May 2003, 03:18 am
pour vous.
http://ptcruiserlinks.com/forum/topic.asp?TOPIC_ID=1745
\"keep your stick on the ice, and your minivan in the right lane.\"
Old 26 May 2003, 02:01 am
It has to see the sky, and un-obstructed. The hockey puck is paintable - the Terk model is. I don't think you could do much good side mounting, and I am afraid you may have too much signal loss if you try a thru-glass mount.
The antenna has been one of the biggest complaints about satellite radio; both XM and Sirius. Most of the aftermarket ones use self-adhesive pads and run the lead-in wired through the hatchback gasket. The stock antenna for the Sirius setup offered by Chrysler requires drilling a hole and passing the antenna wired through the roof.
Old 26 Jul 2003, 01:00 pm
I have the hockey puck antenna on my Ranger and the mini-shark fin on my Cruiser and move my Sony plug n play XM radio easily between the two. I am quite satisfied with the looks and reception of both.
[imghttp://www.imagestation.com/picture/sraid71/p204c3c374e03f2172614cfce51a332d9/fb97fd7c.jpg][/img]
Old 27 Jul 2003, 06:08 pm
Upser14,
Here is a pic of my Antenna Specialists XM antenna:
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 14 May 2009, 01:05 am
JACKFROST4U's Avatar
Default Re: XM Radio Antenna
Hi,
I just joined about a week ago and have a 2006 limited. It came with the black hockey puck antenna. I saw this post and was thinking about painting it.. do you know how to get the paint code for the car, or I was trying to google for covers for it that are pre-painted the color of the car.
Old 14 May 2009, 01:26 pm
JACKFROST4U, welcome to the Forum.
Drivers door, there is a label, look at the bottom line, you will see a PNT:xxx, that is your paint code.
Old 14 May 2009, 04:49 pm
Thanks!
Old 14 May 2009, 10:02 pm
I used my XM antenna on the dash and on a flip platform near the top of the window. Worked well except when going under bridges or in high stands of trees.
I wouldn't do any kind of permanent work until the new dual band radios come out. Sirius-XM will continue to support the old single band radios, but you won't be able to get all of the channels available unless you upgrade.
Installing New Antenna DestroyerMD Exterior Accessories Forum 1 11 Jun 2005 10:40 pm
Antenna removal from Radio therents Interior Accessories Forum 7 10 Jun 2004 10:23 pm
My BTG chromed "shorty" radio antenna... Gary04GT Exterior Accessories Forum 21 12 Mar 2004 08:52 pm
well theres goes my radio JaxPT Non-PT Discussions 11 02 Mar 2004 12:13 pm
Radio drives me crazy!! Alan Welch Sound and Security Forum 2 03 Feb 2004 01:44 pm
