radio/cd player cuts out
Old 29 Aug 2006, 07:26 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Default radio/cd player cuts out
My 2003 (out of warranty) cd player/ radio cuts out intermittently.
I originally thought it was may cd, so I cleaned the cd and the cd player. Changed cd and it still cuts out, I LED goes out. The radio also goes out. Anybody else have or heard of this problem? Any help would be appreciated before I start checking for a short or ground thought I'd ask. I did a search and found nothing. [:I]
Old 30 Aug 2006, 08:40 am
had this happen twice, already. if you have alot of stuff on your key ring, it pulls the key out of the fully seated position. it is enough to shut off the stereo. just push the key back in to seat it. i had the lock cylinder replaced once before. its a double cut key like the old fords, they dont hold well in the lock cylinders.
2003 pt/gt deep cranberry metallic
blow-off valve, 2-1/2\" jeg\'s duals, k&n, 215/50r17 coopers, 10\" lightening audio sub, kenwood 5-channel amp, pioneer speakers...stage 1 soon
Old 30 Aug 2006, 07:24 pm
gonzomania's Avatar
Thanks I tried just using the key with nothing else and it didn't cut out once. I will keep you posted
Old 31 Aug 2006, 04:33 pm
thats so weird but makes sense with the weight on the key ring, keep us posted if it solves the problem
Old 02 Sep 2006, 09:48 am
gonzomania's Avatar
Well it looks like I'm pulling the radio today or tomorrow (depending on Ernesto). I wish I had a place to test it rather than just looking for chaffed wires etc.
Old 03 Sep 2006, 02:49 am
When you take out the radio look for a lose ground wire,that to me sounds like the most plausible culprit.
Old 09 Sep 2006, 12:43 pm
did you fiqure out the problem ??
Old 09 Sep 2006, 09:46 pm
gonzomania's Avatar
Not yet but it seems to be working fine. Need some time to rmove radio but with daughters soccer and pool closing this weekend may be mid week. I'll post ASAP
Old 17 Sep 2006, 12:42 pm
gonzomania's Avatar
Update 9/17/06 disconnected neg battery cable, removed radio from center console found nothing wrong. Loaded my cd manual and found that if radio stops playing it could be a fuse in the junction block. And or it could be a IOD problem. Where is the IOD. Might need some help from MX5 on this one. Also when radio was out I noticed I have another connector block next to the radio harness. I looked in my books and have no idea what this is for.It is an 8 pin socket, any help would be appreciated.
Update as of 9/20/06 checked all ground wires and they seem okay. Noticed when I turn the steering wheel to the left it cut out sometimes. It did this 4 or 5 times, intermittentally cutting in and out. I then gave the shroud around steering column a shot with the heel of my hand and radio cut back in. I have to take a break (this is driving me nuts).
Old 20 Sep 2006, 09:04 pm
you gotta have a loose wire or something thats being pulled when you are turning the wheel
Dvd in dash player gonzomania Sound and Security Forum 13 03 Apr 2005 02:08 am
MP3 player hookup sawdust123 General PT Cruiser Discussions 8 25 Jan 2005 04:03 am
AM FM "RAZ" CD/Cassette Player From 2001 Cruiser Tw3NTy0n3 Classifieds: For Sale/Trade 0 23 Jul 2004 05:13 am
Problems with 6 disc cd player ? ptgtcb Sound and Security Forum 2 30 Apr 2004 01:34 am
My CD player has kidnapped my CD's!! GW Sound and Security Forum 24 20 Jan 2004 09:50 pm
