![]() I just tried to install an aftermarket radio and it won't power up. I have installed several aftermarket stereos in the past, so I have a good grasp on how the install works. I double and then triple checked all of the wiring, fuses, etc and still no luck. I'm wondering is the accessory wire is oddly wired, since the factory radio stays on when the ignition is off (until the door is opened). Can anyone help??
2006 PT Cruiser MTX Base Magnesium Pearl 100,000km/60,000mi |
Thanks for the help - I tapped into my 12 volt plug just above the cup holders.
Good info Zapwizard, thanks. I was just doing an install on m y PT and same result / question. Constant power to the radio with key out.
Did the same as Joe and tapped into 12 VDC outlet above cupholder. FYI - Cupholder in console (rear 12VDC outlet) is always HOT - constant 12VDC, not controlled by car off - key out. Timing for this post was perfect guys, thanks again.
'06 PT Touring
Center console power outlet |
Okay-I'm installing my new after market head unit the second it comes in mail tomorrow. I also have an 06 PT. I bought a Scosche DCCR03SRB / DCCR03SR Wiring Harness Interface Plug for CAN Bus Vehicles. Since I'll be using this wiring harness instead of the generic one, will I have also have to tap into another 12v source? Also, last question...since I bought this really expensive harness that is supposed to utilize the CAN bus interface, will I still have the digital data that displays the current radio station, input, etc? Hope so-that's why I spent the 80 extra bucks instead of going with the common wiring harness that would have come free with the head unit.
It looks like that Scosche adapter is specificaly a +12volt ACC generator, using the CANBUS signal from the car's computer. So you should not need +12volts ACC from somewhere else. As far as digital interface etc... unless someone here owns that interface, then you would have to ask the manufacture.
which wire di you connect to? There is a red and a black one. I connected to the black but my amp is still not turning on. so should i connect to the red one. could it be my ground i have it attached to the hatch latch in the back. thanks.
| 2006 PT Cruiser -Mac Mini install | zapwizard | Interior Accessories Forum | 8 | 05 Jul 2007 02:47 pm |
| 2006 Stereo Install Problems | JOEMAMA | Interior Accessories Forum | 2 | 31 May 2007 01:28 pm |
| 2006 PT Cruiser Pics and New Specs | skylight | PT Cruiser News and Rumors | 14 | 13 Nov 2005 08:46 pm |
| Stereo system install | Dream Bruizer | Sound and Security Forum | 12 | 13 Nov 2004 11:10 pm |
| Stereo Install | silver03 | Exterior & Interior Styling | 7 | 25 Mar 2004 05:40 am |
