External input to factory radio
Old 23 Mar 2009, 08:53 am
Default External input to factory radio
When I bought my 05 L Turbo, the previous owner had installed an XM radio with the controller on top of the dash. I removed it on Friday - while I had the radio out I noticed the input jack with markings. Has anyone attempted to connect to this and does the radio switch when an input is detected? I've tried to find a post in history that addresses this; but all are pointing to an adapter for $60 and up. Is that required? I'm surprised that an input was not part of the radio for an '05, many others were; but then again it still has a cassette player along with the CD...
Oh, my radio works much better (especially AM) after removing the XM with the FM modulator in line with the antenna lead.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 23 Mar 2009, 03:00 pm
Duster's Avatar
Default Re: External input to factory radio
AFAIK, none of the pre-2006 PTs have an AUX jack input.
The jack connector you're talking about is intented to be used with a CD changer.
Old 24 Mar 2009, 08:18 am
Those FM modulators tend to be really really cheap and block quite a bit of signal from the antenna.
Old 02 Apr 2009, 10:39 pm
Send a message via Yahoo to partyd
The radio opends the port only when the cd changer is plug in there
or the auxiliary interface like this
PIE CHRY02-AUX CHRYSLER 2002-2008 AUXILIARY INPUT ADAPTER
Old 04 Apr 2009, 11:06 pm
I bought one of those PIE units - can't use it because it doesn't filter out ignition noise. One very important point I found out about these units - if you don't buy from an authorized dealer, they won't honor the warranty. I got mine on Ebay and no luck getting it replaced.
Old 04 Apr 2009, 11:48 pm
THAT is correct buying from ebay is not a good idea this interfaces are update often with new software version, not authorized dealer can not do that and that is the reason why they sale it so cheap
at the end it cost more
Old 10 Apr 2009, 11:36 pm
I tried to add some ferrite cores to stop the ignition noise. Or rather, I was going to - but decided to check the system one more time. Surprise - it's now completely dead - I can't even select it as an option on the radio.
Rear aux inputs in factory radio, or only front? Aurock Sound and Security Forum 5 15 Jan 2009 09:22 am
FS: Factory Radio moparstore Classifieds: For Sale/Trade 3 09 May 2008 12:02 pm
MP3 CD Changer that fits factory radio Mojito Sound and Security Forum 1 25 Mar 2005 10:46 am
Factory radio switch Dennis Belanger Sound and Security Forum 8 02 Dec 2003 12:23 am
Boosting the factory radio? OVcruzn Sound and Security Forum 13 18 Oct 2003 09:28 am
