Sirius Satellite Antenna
Old 18 May 2009, 08:26 pm
Default Sirius Satellite Antenna
Has anyone ever tried gutting out the stock Sirius antenna on the roof and putting in a newer Sirius antenna underneath it and then glue the stock one back on? Is it even possible to gut out the stock antenna? I did not want to take it off until I knew for sure it was possible. I've read some people with other cars have used the shark antenna to hide the Sirius antenna and still had decent reception. I also came across this as well (MRK Group Ltd. - Sirius Satellite Radio Antenna Cover for Chrysler) but it looks like they don't have white in stock, which is the color of my car, and is why I was going to try this.
I also read that some people had put their antenna inside the car and it seemed to work fine, but when I tried to put it above the rear headliner, it was searching for signal too much. The reason why I was thinking of using the stock Sirius antenna housing if possible, is because the Sirius antenna that comes with their kit has the wiring coming off the end and I don't see a way of using the existing hole which was drilled without having to worry about filling in the hole since the antenna will not be covering it.
If this is a stupid idea, please just say so I'm open to any other suggestions and am under the impression that the newer antenna would receive better reception over the older one which is why I have not gotten an adapter (even though it is much smaller, plus I just installed the new head unit and Sirius kit this weekend and too impatient to wait for an adapter). I just did not want to have two antennas on the top of my car nor have to worry about filling in the existing hole if the original was removed.
Thanks.
Old 25 May 2009, 02:00 pm
Send a message via Yahoo to partyd
Default Re: Sirius Satellite Antenna
you can use the stock satellite antenna from a new vehicle
this works with Sirius or xm the only modification that needs to be done is on the plug end just change the end plugs and it will work
Sirius Antenna Location kelecoleman PT Cruiser Convertible Forum 2 10 Apr 2009 11:21 am
Painting Satellite Antenna sfree8321 Sound and Security Forum 4 08 Jul 2005 01:26 pm
Antenna mounting Sirius w/ RB1 Nav Sys sfree8321 Sound and Security Forum 7 08 Jun 2005 06:33 pm
Kenwood Sirius Satellite Radio System Dalite Sound and Security Forum 4 01 Jul 2004 12:19 pm
Sirius Brings Wall Street to Your Street Rolo Non-PT Discussions 0 11 Feb 2004 08:33 pm
  Wordpress Themes | WoW Gold | Debt Consolidation | Debt Consolidation | Wordpress Themes
