Originally Posted by chris15
Ah, I understand. I suppose I interpreted what you were saying a bit differently than you had intended.  My apologies.
When you say 'picnic table' are you referring to the storage shelf?
And to address your dimming situation: have you attempted the hyperground configuration yet? I had the same problems that you listed and was told basically the same things: higher output alternator or an Optima battery, or a capacitor. I'm of the type of audio enthusiast that doesn't like adding extra loads to a system so I didn't like the idea of adding a cap. Then I ran into the hypergrounding topic, ran a couple wires from my battery and viola! problems solved.
Yes, my new PT did not come with the storage shelf unfortunately.
Re: Hypergrounding Topic - Is this a topic in the forums? If so, could you provide me with the URL (I searched and couldn't find anything). If not, could you provide with some insight on this? Or is this the same thing as suggested by bobdole369 (Thanks for your suggestion!). If they are not the same suggestion, I will try them both. Never thought that running a ground from battery to chassis would make that much of an impact.
