When I put my Polk components in, I tested them, sounded great, put all my panels back on, drove around the block and the second I turned the speakers up, I noticed that the left tweeter was extremely, extremely quiet, giving me a very odd mix of sound. I, like you did, adjusted my balance to compensate until the next day when I could pull everything apart again.
My problem was that I had soldered my new speakers in, and one of the grounds on the tweeter had let go as I was installing it, but because the space was so limited inside the hole for the tweeter, the ground wire was still rubbing on the connector, so I was getting sound but nothing good. Unfortunately in your case, you're probably going to have to pull it all apart again, and check all of your connections.. :/
2001 PT LE ![]()
![]() The thought of going back to my wiring mess behind the stereo was making me crazy. Hopefully all of my connections are tight back there. Having the RAQ and the tweeters in place makes all of the effort worthwhile. |
It's pretty unlikely that the problem lies at the back of your headunit, but if you look around and all your speaker connections are fine, could possibly be a bad connection to your headunit, or something's wrong with the tweeter itself.
Let us know how it turns out.
2001 PT LE ![]()
Issue turned out to be with the wiring behind the radio, took everything apart and rewired it from scratch. I also found I reversed the positive/negative on one of the tweeters. Now I am an expert on stereo wiring for the Cruiser, I may have to rent myself out on the weekends
![]() It is short of amazing what the RAQ and the missing tweeters do to the sound when you are used to the base setup. |
| External input to factory radio | garner49 | Sound and Security Forum | 6 | 10 Apr 2009 11:36 pm |
| After market radio and Sirius | LucianoG | Sound and Security Forum | 2 | 20 Dec 2007 03:04 pm |
| Sirius and After market radio.. | LucianoG | General PT Cruiser Discussions | 2 | 20 Dec 2007 03:00 pm |
| Radio drives me crazy!! | Alan Welch | Sound and Security Forum | 2 | 03 Feb 2004 01:44 pm |
