Radio and cd player work just fine , readout goes on and off. I know this has happened before, just wondering where to start looking....Thanks Ed
This Black Thing Keeps Chasing Me ![]() YES ! That is a Ron Paul for President Sticker.. ![]() Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood ![]() Ed Sidders , Lake-O The-Pines , Northeast Texas |
Thanks , those are the symptoms , I just have this thing about fixing stuff. I always enjoyed the challenge. My hearing has gone to the point that I can't tell the difference between a $5 transistor radio and a $10K music system.
Jefferson Airplane,Greatful Dead, Zydaco,Swamp Pop and Mary Gauthier still sound good on anything.. I think I'll slip it out and play with it a little and if no joy I'll see what Crutchfield has for a replacement..Don't really want to put a $100 saddle on a $5 horse..Thanks again.Ed
There might be a fix for it but aftermarket decks are so cheap and easy to install these days, there's not really any point. If you're wanting to try and fix it, take it apart and have a look. It's already broken right?
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
02 limited same problem , cd and tape radio
i took it out remove the face and resolder all the points behind the display the problem is just a cold solder point, so the radio is fix it never happend again is been 3 years
2004 pt cruiser gt 2004 chrysler 300m 2004 town and country |
That is pretty much what I suspected---Ed
UPDATE--clock/readout goes on and off when I move the steering wheel up and down..Also horn ----suspect wiring harness connection...more later when weather cools....I aint a kid no more
Some reason on my 06 PT when I turn on the car the radio does does not work at all. SOme cases the radio works fine. Is there a short in the radio or wiring?
what year is your vehicle?
I don't believe there is a short in wiring the plugs are very good quality and i neever seen problems with the radio wires in any chrysler vehicle
2001 Limited - Same problem. Seems to be in the headlight / turn signal switch. Power or ground, haven't figured which. If I press on the wiring harness for the headlight switch or lift up on the wheel the radio display and horn work again. Looks like the switch depends on being grounded thru the steering wheel tilt mechanism. Over time this connection has gotten worn and very dirty / rusty. I need to add a ground wire from the switch to solid ground to check if this is the problem. Or I need to somehow clean tilt mechanism. Will updated you when I fix the problem.
