Aftermarket headunit gets constant power. Please help!
Old 04 Aug 2009, 11:43 pm
Default Aftermarket headunit gets constant power. Please help!
Ok, so I finally got a 07 Cruiser 2 weeks ago and I just now got to installing my aftermarket head unit, amp and sub. I went and picked up a wiring harness and I ran into a little problem. The constant power wire went to nothing. On the factory harness I have 2 red wires, 8 speaker wires and a ground. I hooked it up, after having to modify the aftermarket harness since the wire that supplies constant power to the HU went to nothing on the factory harness, and my HU stays on even when I turn the car off. Then I broke out the current detector and found what should be the memory wire since it the the one out of the 2 that had current going to it with the car off. So I rewired the aftermarket harness again and now I still have constant power running through both wires and my HU still stays on. Needless to say I'm about ready to pull my hair out. Also, I'm having a hard time finding somewhere to ground my amp in the rear cargo area. Any help would be greatly appreciated. I know I'm a newbie, but I searched through almost every thread and couldn't find any answers, so I'm sorry if this has already been covered.
Old 07 Aug 2009, 07:35 pm
ADR's Avatar
ADR ADR is offline
Default Re: Aftermarket headunit gets constant power. Please help!
I've got an older PT so I didn't have any trouble, but the newer Chrysler vehicles now use that crazy CANBUS system that controls the power of the radio through the BCM. Your PT may have this type of radio.
Scosche and Peripheral both make an adaptor that takes care of your problems. It's a little black box that should have come with your wire harness.
Looks like this:
Peripheral Electronics
The other possibility is that you have purchased a defective wire harness that is missing the two yellow wires
Old 29 Aug 2009, 01:29 am
i had the same problem with my 06 cruiser, i could not get it to turn on, after futher investigation i found that there was no ignition wire coming off of the harness, the wiring harness does not have a ignition wire. (red wire) so you will have to find a ignition wire some were in your car. luckly ive already did this and i no where one is lol.
THIS is how you solve it with out spending money.
pull your carpet away from the lower part of your center consle. located the cigerette lighter power wire/ground wire. its going to be in a black mesh sheilding.
theres 2 wires so make sure you do not cut through the ground. The pink wire is what you need to splice into. splice it and run a wire up to the red wire on your cd player. make sure you re connect the cigerette lighter wire and properly wrap it so you have no exposed copper.
once you do that the cd player should turn on and off like normal.
hope this helps
Enkei WDM Rims, Falken Ze-19 Tires, Flowmaster Super 44, K&N Cold Air Intake, AirRaid Throttle Body, XEON Head Lights, Crunch 1100Watt Sub Amp Running Two 12' 1200watt Square Hifonics Brutus Subwoofers, 900Watt Crunch Highs Amp Running 12 Power Acustik Speakers. Pioneer head unit
Old 29 Aug 2009, 01:32 am
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
I used the Scosche wire harness and did not have any issues. Everything worked the first time!
2007 Touring Edition
Exhaust: Borla
Front: ODaddyO
Headunit: JVC KD-AVX77
Hood: ODaddyO
Intake: K&N Airraid
LED's: Oznium
Rear: ODaddyO
Speakers: Polk DB6501
Springs: Gold Line Slammers
Strut Bar: BTG Turbo
Subwoofers: Alpine SWR-1243D
Tailights: United Pacific LED Teardrop
Visor: Cal Cruiser
Check out my progress
My Facebook Add me!
Best source 12V constant power DJRyan Interior Accessories Forum 3 21 Dec 2007 07:13 pm
Guide: 2006 Power windows and Sunroof always on. zapwizard General PT Cruiser Discussions 3 21 May 2007 09:23 am
Stock Sirius Radio and Aftermarket Headunit? blueberrygt Sound and Security Forum 1 17 Apr 2005 08:41 am
PT Cruiser aftermarket power door locks baird11 Interior Accessories Forum 5 20 Jan 2004 08:42 pm
Aftermarket Equipment VS Warranty Dalite General PT Cruiser Discussions 1 06 May 2003 01:28 am
