Ok, first off, there's a common misconception involving the power handling (wattage) of speakers. Note that phrase: 'power handling'. The 300-watt rating that your speakers have does not mean that the speakers operate at 300-watts constantly. What that DOES mean (in general terms) is that your speakers can ACCEPT a maximum frequency of 300-watts FROM a source (your stereo). Your speakers don't affect your stereo, your stereo affects your speakers.. make sense? So when the Crutchfield tech told you that your stereo can 'handle' the speakers, he wasn't wrong-- he just didn't take the time to correct the misunderstanding.
Now, on to the speakers.. If you can access them easily, I would test them. Remove the speaker wire connectors from the speakers and use a 9-volt battery with two leads from positive to negative of the battery to the positive and negative of the speakers and see if you hear anything. (Don't worry, the battery won't harm your speakers whatsoever.) It should make a muffled sound when you move the wire leads around on the connectors, kinda like someone's rubbing your head with a pillow. If you do hear something, your speakers are fine. On the other hand, if you hear nothing, there's a very good chance your speakers are bad. Secondly, I THINK you implied you're not using an aftermarket amp, but just in case-- are you using an amp? If you are, then there's another loop of troubleshooting for that situation. Seeing as you have power to your headunit, I doubt it's a fuse. Sounds like it's either your speaker connections or the speakers themselves.
2001 PT Turbo - In the process of a major overhaul.. :] 2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
Thanks for the info , am not using an external amp just whats in the stereo
i do have one am about to install a sub, an update on my speakers angry at my self thinking i did somthing wrong i pulled out my stereo and did see a # 10 fuse in the back i pulled it out then back in same with all the wires I did notice a reset push botton on the inside face plate i reset it pluged everything up hit power and my speakers came on! i dont know what happen but they sound way better then when i first tryed it i dont know if my stereo had to be reset do to the power diffrence i dont know but its working great right know thanks for the help.
Good to hear.
Honestly, not too sure about the 'Reset' button solving your issues. Sounded like a connection problem to me. I would've isolated the issue by turning it on after re-seating all of your connections, and if the problem was fixed, you knew that's what it was. As for the magic 'Reset' button-- if that was what fixed it, you could just be covering up an underlying problem with the deck itself. Anyway, that's just the realist in me, brainstorming. Glad everything's up and running for ya.
Well you were right it worked fine last night woke up this morning started the car and guess what yea no sound again... so i did the (magic button ) again and no it did not work ....
I left the unit on headed to town and about 5 mins of driving the speackers came on went to work 10 hrs later i tryed it again and no sound .... so yes theres a problem some were am gona say its not the radio it self it was working fine with the stock speakers so am gona say its the new speakers , wireing problem? i used the cruchfield speaker wireing harness that came with them i did have to cut the ends to make it fit in the new speakers the other end fit just right to my stock wire this is my first stereo project .. and i just got my new amp and sub in the mail hope i dont have more problems... |
| Clicking and humming sound from front end? | Samson | Wheels, Tires, Suspension | 5 | 06 Aug 2009 08:34 am |
| Trying to explain "the sound"... | blucrsr | Wheels, Tires, Suspension | 12 | 10 Aug 2005 07:31 am |
| CRICKET SOUND FROM ENGINE ? | JGN | General PT Cruiser Discussions | 11 | 05 Aug 2004 07:04 pm |
| Optimum sound question | stirfry | Sound and Security Forum | 3 | 12 Apr 2004 09:49 pm |
| Strange fluttering/rattling sound!? | gsharrock | Turbo Performance | 19 | 21 Aug 2003 09:46 am |
