Ok, so I put off getting my ghost flames painted on my 07 so I could finish my audio system. This is what I ended up with
Alpine CDA105 head unit Boston S35 3.5" dash speakers Alpine SPS 6.5" door speakers Got rid of the rear speakers. They're pointless 2 12" JL W1V2 subs in a ported box Rockford P200-1 pushing the door and dash speakers Rockford P500-1 pushing the subs Ok, so when I kill the subs and turn the volume up, the door and dash speakers sound great. However, when I add the subs at a moderate level, I get distortion from the dash and door speakers. I could take my car to a shop and pay who knows how much to get it fixed, but I thought that I would check on here first to see if anyone knew of a cheap fix to this problem. Thank you for any advice anyone may be able to provide. |
you could have a possible grounding issue. Or need to purchase some type of cap.
where do you have your amps grounded to??
![]() Enkei WDM Rims, Falken Ze-19 Tires, Flowmaster Super 44, K&N Cold Air Intake, AirRaid Throttle Body, XEON Head Lights, Crunch 1100Watt Sub Amp Running Two 12' 1200watt Square Hifonics Brutus Subwoofers, 900Watt Crunch Highs Amp Running 12 Power Acustik Speakers. Pioneer head unit |
No point in a cap, like pissing in the wind. Ground the system better. period. 4 AWG from a very good (read NEW, as in drill the hole, tap it, put it in yourself) ground point to the negative terminal of the battery. Connect the alternator and engine block to the same point. Run your ground cable for your amplifiers from that same point.
Also you should have at least 4AWG from the positive terminal of your battery, through a big ole fuse (like 50-100A) within a few inches of the battery. Make sure you grommet any hole the 4AWG runs through, esp through the firewall. Use a good quality distro block at the amps, each line should be fused in addition to any fuses the amps/crossover/processor uses. Quite likely when you turn on the subs you are using a bit more power, and the PT is known for terribly ground loops/lost voltage/drops from any run into the back hatch area. You pull a couple hundred watts and its voltage drop city. It's quite good advice to search "hypergrounding" on this forum. What are you using for a crossover? Perhaps you are loading the processor/crossover and thats causing a mismatch elsewhere in the system? |
I actually have 2 power wires coming off my battery. One is 8awg for my P-200 and I have a 4awg for my P-500. The same goes for the grounds. I have a 40 amp fuse on the 200 and a 100 on the 500. As far as my crossovers, I'm using the ones that are on the amps.
The thing that confusing me is if I have a voltage drop when my subs are getting pushed fairly hard, wouldn't my lights dim? If it were a voltage drop, wouldn't hooking up a 1 farad cap fix that problem? My initial thoughts is that maybe my speakers aren't sealed very well, causing my speakers to "flutter" whenever the bass notes hit. I'll do whatever is necessary to get rid of this problem, but I'm not about to mess with the "Hypergrounding" thing you just described. I'll pay someone to do that. Darkpt06--I have them grounded next to the latches that the rear seats hook on to. Sorry if that didn't make too much sense. My sleep medication is kicking in. |
Ok well that ground may not be the best ground. thats most likely your issue
i have my sub amp and highs amp grounded to the bolt NEXT to the drop down bolt for your spare tire, and i have no feedback. the power wire may not be an issue but you maybe limiting your self with power due to the gauge of the wire your using. for example, i have a One 4gauge power wire running to a Fuse box and from there splits into 2 wires going to my amps. what you said about the dimming of the lights is a problem that would be fixed by a cap. If you didnt no or for the people reading this that do not know, caps are used to store extra voltage, that extra voltage is used when you get a spike in power (ie when you subs hit), thus if you do not have a cap, and you getting dimming headlights and gauge lights you would have to purchase one to keep that from happening. i personally do not have a cap in my car.
Quite possible you get a ground loop going when power draw is heavy. Try running a heavy gauge from the head unit to the neg on the battery too. Just a thought there, since your head unit gets ground through the dash, which is generally pretty poor. You do have the high-pass on the non-subwoofers going right? so you aren't sending bass to your door and dash speakers? Just checking. |
Chris15--My sub amp is always on. I kill the bass by using my subwoofer gain on my head unit. I know I have a ground loop because I hear that turbo-sounding whine when I accelerate and have the stereo at a low volume. I remember way back in the day that a local radio shop fixed the ground loop I had in my 72 Dart by running a wire (I have no idea what it was from) into one of my RCA wires. For $15, I think I'll try one of those ground loop isolators. If that doesn't work, I'm too busy with my kids (I'm a single dad) and college to mess with anything more complex, so I'll just take it to the pros and have them figure it out. Then I'll have to put off getting my baby moons
Of course I have the High Pass filter running on the 200! The worst part about all this is if this had happened 10 years ago, I'd have all this fixed with no problem. I figured the 2 years of electronics I took in high school would help me with all this...Once again, thank you all for your help. I really appreciate it. |
>.> hmm you do you have ur sub amp bridged??
When you turn it back on (by increasing the gain on your head unit) you are changing the output of all channels. (yes confusing but hear me out) Could be that your overloading the preamp outputs on the head unit when the gains are up. Any way to reduce the output of the head unit (such as limit the volume and compensate by slightly increasing the gain of the amps?) Recall that each output is likely on a common voltage rail, so that when you crank the sub up, the preamp output on all channels suffers. I know on my head unit, I have a max volume setting of "30", but everything above 27 gets distorted and clips. When I use the in-built EQ and set anything above "+3", then I must limit the output to under 25 or the same thing happens. Perhaps set the EQ or any gains to Flat (or 0) and see if it happens there. I'm starting to suspect the head unit is part of the issue here. Quote:
Caps are a bandaid and likely cause further issues. Last edited by bobdole369; 11 Oct 2009 at 10:35 pm. |
| speaker issues, wattage of stereo, door speaker replacement issues | fabes89 | General PT Cruiser Discussions | 9 | 02 Jun 2009 10:59 am |
| Front Dash Speaker sizes | valcansa | Sound and Security Forum | 2 | 27 Apr 2009 09:36 am |
| No Dash Speaker Wires--Need Install Instructions | everydayking | Sound and Security Forum | 1 | 02 May 2008 11:27 pm |
| vibration causing dash to rattle | Easymover | Tech & Performance Forum | 3 | 26 Jan 2006 07:34 pm |
| dash speaker replacement | eliminator | Sound and Security Forum | 3 | 16 Feb 2005 11:19 am |
