KEYLESS ENTRY stop working
Old 01 Nov 2009, 10:50 pm
Send a message via Yahoo to partyd
Default KEYLESS ENTRY stop working
Keyless entry stop working, no lock or unlock or panic both remotes stop working at the same time dealers tells me that is need to be repair or replace
how do i reprogram this unit ?
where is the keyleess entry ? maybe i can repair it
thank you
2004 pt cruiser gt
2004 chrysler 300m
2004 town and country
Old 02 Nov 2009, 02:08 am
Duster's Avatar
Default Re: KEYLESS ENTRY stop working
where is the keyleess entry ? maybe i can repair it thank you
In the middle of the dash, right on top of it...if you prefer, under the dash cover, in line with the defrost air vent and the center console.
Here's a picture:
© 2009 - Candyman's dash picture
Old 02 Nov 2009, 09:29 am
Yup. To get the cover off, pry out the window switches to expose a screw that holds it on.
Old 02 Nov 2009, 03:38 pm
Duster's Avatar
Look at the first 2 files in this thread:
Speakers removal HOW TO
I can resume the process for you though.
1. Remove the power windows switch panel using a thin knife (butter) or something. Pry gently. Then disconnect the harness.
2. Remove all the 4 climate system knobs
3. Unscrew the Phillips screw behind the power windows panel
4. Pry out the center consol trim. No more screws, only some metal clips hold it
5. You will now see 2 Phillips screws each side of the first screw that you removed already. Unscrew them all.
6. Remove the "A" pillar cover. No screws, only metal clips involved.
7. Pull the dash cover to release the metal clips that hold it there
8. Pry up the front edge of the dash cover and then pull it toward you
9. You'll now see the keyless entry module in the middle of the dash
Done!
Old 02 Nov 2009, 05:53 pm
thank you
I remove the windows switches with a flat or Phillips screw driver
remove one Phillips screw
stick my hands in the hole and pull hard
takes me under a minute to get there later i look for the ac controls under the seat lol
how can i reprogram this unit ?
2004 pt cruiser gt
2004 chrysler 300m
Old 03 Nov 2009, 12:34 am
Duster's Avatar
I don't know...sorry. In fact, I don't know if it can be "unprogramed" or just dead.
Old 08 Jan 2010, 08:54 pm
Did you ever determine if you could repair your unit or did you replace it? My PT has the same problem.
Old 08 Jan 2010, 09:11 pm
NOO i pull the TRW brain and it is here in my desc i don't see a way to program this with out the obd2 crysler computer
the other idea was to find a use brain from the junk yard from a pt cruiser with the remote, or install a viper alarm system in the same factory location ( middle of the dash ) i found power,ignition,parking lights,door pins,siren,hood and rear hatch pins, also somelight supervision
i just have to run a calbe for the kill ignition
2004 pt cruiser gt
2004 chrysler 300m
Headlights, keyless entry & instrument cluster lights not working RTCruiser General PT Cruiser Discussions 2 06 Jul 2010 09:13 pm
Keyless entry unlocks driver door only- indoor locks not working Candace Tech & Performance Forum 9 14 Oct 2009 05:48 pm
Why is my Autoloc keyless entry fob working backwards? bettyrubble76 Interior Accessories Forum 8 19 Sep 2009 12:45 pm
Keyless entry remotes not working strack18 Tech & Performance Forum 1 27 Jun 2009 08:26 am
KEYLESS ENTRY? DevilMan General PT Cruiser Discussions 1 01 Apr 2006 08:48 pm
