Unlocking door with key causes Alarm Activation
Old 08 Mar 2010, 08:51 pm
Default Unlocking door with key causes Alarm Activation
Over the last year, I have been experiencing an extremely odd issue. Whenever (all keys are affected) I unlock my driver side door with my key and open the door, the alarm goes off. If I use the FOB to unlock, no issues. It has gotten significantly worse...it started with every once in a while, now it's every time.
I understand there are two parts which could be the culprit. Something on the door itself (the lock cylinder mechanism?) and the RKEM device in the dash.
To be completely honest, I would rather not spend a dime to fix this.
I have attempted to pull a couple of fuses that I thought may rectify the issue, but the ones that do affect other things as well. Is there a fuse that I can pull or swap that will solve/bypass the issue?
I know (from taking apart the dash before) that the RKEM module has a wiring harness connected to it. I am no stranger to electronics, and if I either had a diagram or knew which wire(s) to cut, I would just cut them to disable part of or the entire alarm.
Does anyone have a suggestion on rectifying the issue?
Thanks!!!!!
Old 08 Mar 2010, 09:43 pm
bds02pt's Avatar
Default Re: Unlocking door with key causes Alarm Activation
My car does this also. I always thought it was the remote starter I have installed reacting with something. Guess it could be something else if you are having the same issue. I just always use my remote to unlock.
Old 08 Mar 2010, 09:49 pm
I have a remote start as well. This started before I installed that, though.
Old 31 Mar 2010, 12:50 pm
chris15's Avatar
It's not an 'issue'. Mine does it as well. I don't know of a way to change the behavior of the security system.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 31 Mar 2010, 03:41 pm
William_F's Avatar
Manually lock the doors when you exit the car as opposed to using the fob or main driver's side lock.
I got my car used and it didn't come with remotes and I wasn't ready to shell out $200 to get one, so I did a little research and found out that the alarm only arms if the doors are locked electronically via the fob or lock on the door.
Pushing the lock pins down by hand on each door will lock them without arming the system.
Old 04 May 2010, 09:19 am
pegn's Avatar
I recently programmed a third key for my 2001 PT Cruiser. The second key lost its programme and I had to go through the programming sequence a second time. Since then, my alarm is always activated, regardless of key fob, manually locking the doors or using any of the 3 keys. The red light on the left gauge shows the alarm is activated, and the honking whenever I unlock the driver's door is causing ill feelings from my neighbours. Any idea how I can turn off the 'always activated' condition so that I can lock the doors with the fob and then disarm the alarm with the fob? (As of now, using the fob does not stop the alarm, I must put the key in the ignition.)
Old 12 May 2010, 08:48 pm
pegn's Avatar
Doh! I've been using the driver's side master lock or having my passenger do it on their side in an attempt to foil the alarm. Double doh! All this new (to me) technology is working the old brain cells!
Old 13 May 2010, 09:51 am
William_F's Avatar
I wasn't born with that knowledge. I found it here just like you did
Glad I could help someone else out for a change!
Problem with door locks and alarm. my_dads_pt General PT Cruiser Discussions 4 24 May 2010 12:07 pm
problem with door alarm viper111059 Tech & Performance Forum 2 07 Dec 2009 09:43 pm
Front Lights on when locking/unlocking Netname Tech & Performance Forum 5 12 Sep 2008 10:14 pm
door locks locking/unlocking on their own! talisman Tech & Performance Forum 11 09 Mar 2008 06:23 am
Power locks locking/unlocking while driving? vk General PT Cruiser Discussions 16 28 Feb 2005 12:06 pm
