PT Cruiser Forum Car Videos
Custom Wheels
HELP: Alarm keeps going off for no reason
Old 18 Oct 2003, 04:56 pm
jsanford jsanford is offline
Default HELP: Alarm keeps going off for no reason
This just started today, after having my car for a little over 2 1/2 years. My Alarm goes off every five minutes of so, I don't have a motion sensor for the system, someone has to physically open one of the doors for it to go off. So I have no idea what's up with it. So right now I have to put my alarm in Valet mode.
Has anyone run into this issue before, or heard of someone having this same problem? If Yes, how can I fix it myself, or do I need to bring it in to get it fixed. Who would I bring it too? The Dealership?
I don't remember the name of the alarm system I have, but it was the one offered in the PT Cruiser brochure for the 2001 models.
Thanks,
John Sanford
[xx(] Please make it stop....
Old 01 Nov 2003, 06:45 pm
Goldmember Goldmember is offline
Send a message via AIM to Goldmember
Mine never went off when it was broken into, just my luck
Boring Gold PT, oops that was 4 years ago
Old 01 Nov 2003, 06:49 pm
GTSteve GTSteve is offline
Do you think a shock sensor would have helped? I see they pried the door out and hit the unlock button. Am I wrong? Shouldn't the alarm go off in that case? Don't you have to use the fob to disarm the alarm?
Old 01 Nov 2003, 08:50 pm
Hooligan Hooligan is offline
Check www.ptdoityourself.net, go to Section Two, Look under TSB's/ Recalls etc.; intermittment alarm. That area mentions reasons. That website should be bookmarked by every one who owns a PT.
Good Luck[8)]
Old 11 Nov 2003, 10:10 pm
USAFJoe USAFJoe is offline
Have your battery checked. Some cheaper alarms simply use a voltage sensing ciruit to monitor the car, when the door opens the dome light comes on and in result there is a slight voltage drop on the battery. Sometimes if an alarm is using a voltage sensing ciruit and the battery is getting old, it will cause false alarms. Worth a shot if nothing else works.
Old 14 Nov 2003, 08:19 pm
98 Neon Driver 98 Neon Driver is offline
If it's an after market alarm w/ a shock sensor, and you live in a cold area, the temp change will also set it off. I have mine set really sensitive (fart and it goes off) and it'll go off when it's cold for no reason
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
vB code is On
Does an alarm come standard w/ PT Cruiser? Cruising Mike Sound and Security Forum 4 11 Jun 2005 11:37 am
Car Alarm??? lightyears Sound and Security Forum 12 07 May 2004 04:08 am
BURGALR ALARM FOR NEW PT MAESTRO General PT Cruiser Discussions 6 02 Apr 2004 10:32 pm
ALARM SYSTEM RAK Sound and Security Forum 6 14 Jan 2003 01:33 pm
alarm install jason Sound and Security Forum 2 30 Oct 2002 12:57 am
  Loan | Mobile Phone | Extranet | eBay | Compare
