OOPS - Forgot the windows again...
Old 31 Oct 2003, 04:24 pm
Default OOPS - Forgot the windows again...
How many times have you turned off the car, got out and noticed the rear window still slightly open - usually to eliminate that wind booming sound? I am constantly "forgetting" to check my windows.
This is probably getting on the complicated side, but I would like a light that would inform me when [u]any</u> window is not fully closed.
I have seen the DIY article on hotwiring the switches to fulltime power, but was wondering if my thought was practicle...
Old 31 Oct 2003, 05:48 pm
micros switch inside door, wired to led on dash, to keyed fuse.
Old 31 Oct 2003, 09:00 pm
Stephen R., Punch, check this out http://www.buildmet.com/pwc.html
Here's the description:
Our power window controller is designed with a two button interface for raising or lowering an electric motor powered automobile window. The power control to the motor is by a relay. The system features an over current sensor which prevents motor overloading or burnout. This is also used to detect window jams or obstruction. A separate input is provided to sense the central locking signal from any car alarm system and automatically raise all windows. The system will need to be customised for a specific car type or window and we will need technical info regarding the type of motor used. An additional feature is implementation of delay timing for each window which ensures that all windows do not go up simultaneously.
Also found something at Crutchfield's:
Crime Guard Au93-4
4-window Roll-Up Module
Add-On or Stand-Alone Operation: This module can be used as an add-on to an aftermarket alarm system, or it can be connected as a stand-alone device. As an add-on, the module can be connected to work with a remote controlled alarm output, or it can be connected to a starter disable output that is active whenever the alarm is armed. If you connect the unit to an alarm's starter disable output, the windows will be automatically rolled up whenever the alarm is armed. When used as a stand-alone device, the module can be manually triggered with a toggle switch (not included), or a relay (not included) can be connected to trigger the module when you turn the ignition off. When a relay is connected to trigger the module when the ignition is turned off, the windows will be automatically rolled up every time you turn off the vehicle.
http://www.crutchfield.com/cgi-bin/S...nfo&i=514AU934
2002 Inferno Red PT Limited
Mercedes Wiki
holy crap !! cleaning windows!! what to use?? bobs turbo pt The Detail Shop 7 16 Sep 2005 09:33 am
windows up/down with A/C on/off bigdogdad Tech & Performance Forum 1 09 Aug 2005 05:02 pm
rear windows rattle gonzomania General PT Cruiser Discussions 6 06 Dec 2004 03:03 pm
Windows Paintball3r The Detail Shop 19 11 Nov 2004 10:43 pm
How to remove water spots from windows? beard General PT Cruiser Discussions 9 06 Oct 2003 09:20 am
