You should have an owners manual that explains how the alarm system works.
If you want to be sure, roll down your drivers window, lock the car and then reach in and pull the door handle open. If you have an alarm (horn & lights) it will sound the horn and flash the lights for about 1 minute and then reset itself. |
or you can pull off your negitive battery cable and reconnect it...if it has one.... it WILL go off LOL Trust me on this one.... its loud! and the idiots put the horn right next to where you put the battery cables back on at :{
Chrysler must have really changed things around in the 06+ models because in the 00-05 models, the negative battery cable is on the drivers side whereas the horn is under the inner fender on the passenger side.
lower the drivers window, close the door and lock the vehicle with the remote wait one minute and stick your hand inside the vehicle and open the
door ( DONT USE THE REMOTE TO UNLOCK ) see if it makes a noise from the alarm horn
2008 Pt cruiser Touring 2004 Pt Cruiser GT 2004 Chrysler 300M 2008 Chrysler Pacifica awd |
![]() Quote:
If you read post number #2 of this thread, I already suggested that. ![]() |
The red light also is used for the key sentry system. The keys have a little chip which communicates with a module under the ignition switch and if a key with the wrong chip is used to try and start the car, the car will shut off after 2 seconds. The red light comes on for 3 seconds as a bulb check. If the light stays on this means there is a problem with the electronics. If the the bulb flashes it means the key is not programed to the vehicle. Either of these conditions will cause the car to only run for 2 seconds.
I put a blinking LED in my PT as a theft deterent. Not hooked to an alarm. Just an LED so that people see it on my dash and think there's an alarm. =)
2005 Pt Cruiser 2.4L Auto Trans 1964.5 Mustang Coupe I6 170ci C4 Auto Trans |
Thread Tools | |
Display Modes | |
How not to set alarm off | sammym2511 | Sound and Security Forum | 2 | 19 Apr 2010 10:01 am |
Theft alarm light stays on 24/7 | slong | General PT Cruiser Discussions | 0 | 16 Jun 2008 09:45 pm |
But I don't have a car alarm! | SJGW | Tech & Performance Forum | 7 | 26 May 2005 02:02 am |
Car Alarm??? | lightyears | Sound and Security Forum | 12 | 07 May 2004 04:08 am |
ast alarm | kerryman | General PT Cruiser Discussions | 0 | 18 Aug 2003 04:13 pm |
