PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Sound and Security Forum (http://www.ptcruiserlinks.com/forum/sound-security-forum/)
-   -   Replacing Chrysler's OEM Security system. Any advice? (http://www.ptcruiserlinks.com/forum/sound-security-forum/31648-replacing-chryslers-oem-security-system-any-advice.html)
Kell 23 Sep 2010 02:27 am
I'm at the point where I wanted to replace the stock system in the PT with something better, and I bought a Clifford Matrix 1x to do the job. The install is now finished! Unfortunately, the installer turned the key with the front dash off, so my PT is now showing an airbag indicator.
... and disconnecting the battery cable for 5 minutes isn't clearing it, nor is it coding (I wiped the bank anyway, no dice.)
So, I'm guessing they either damaged the sensor when they went to loom everything, or the warning takes longer to clear.
