amp install
Old 19 Jan 2011, 08:51 pm
Default amp install
i have installed my amp but its not staying on. so i took everything out. where have you grounded your amps at in the back?? im thinking i may have hit a not so good spot. im replacing the remote wire too. so basically where have you grounded a amp before in the pt????
Old 19 Jan 2011, 11:33 pm
Default Re: amp install
I took the cover off of the bottom of the trunk (the part that houses the lock for the hatch and the spare tire bolt) and drilled a ground. I used heavy grit sand paper to remove all the paint, and used a screw (also conductive) and have had no problem running my system.
Hope this helps.
Old 28 Jan 2011, 03:09 am
An amp produces some heat during operation, which its heat sink absorbs and radiates, so it needs a few inches of air space to stay as cool as possible. When mounting an amp on a side wall, make sure the fins on the heat sink are vertical. Never mount an amp upside down, as dissipated heat will radiate back into the amp.
VLC Media Player Download
i-Pod Install smallfrycruzr Sound and Security Forum 4 12 May 2010 07:31 am
AGP WGA install hoopdiewagon General Turbo Discussions 2 08 Jan 2005 01:42 am
BTG CAI install Punch Turbo Performance 4 14 Oct 2003 10:36 pm
BOV Install RODRUN Stage Turbo Kits 7 12 Oct 2003 11:27 am
BOV install??? COP TZER Turbo Performance 10 24 Apr 2003 07:53 pm
