Double Dinn
Old 18 Mar 2011, 10:41 am
Default Double Dinn
Hey Guys,
Would like to replace the stock head unit with an Alpine unit with GPS etc..
Will a double Dinn fit in a 2006 GT?
Thanks
Old 18 Mar 2011, 11:12 am
Kawizx9r's Avatar
Default Re: Double Dinn
Plug n play?
Nope, least not for PT's up to '05. If it's the same for 06+, then no.
With the removal of the center panel, hacking away and modifying it?
Maybe.
If you insist on going with this Alpine headunit, I'd suggest you find a panel at a local Pick N Pull and work on that. This way if you ever go back to stock, or with a single-din headunit you've always got the stock center panel.
Kawi is a friggin genius!
Old 18 Mar 2011, 12:51 pm
I don't believe the opening for the head unit in the '06 and up is double-DIN, I think it's an oddball 1.5 DIN. I know that I have a single DIN unit in there, in an adapter plate, and the bottom half that is filled is less than the height of the single DIN head unit, that tells me it's not a double-DIN opening. Guess you could modify that to make it fit but it'll be ugly.
Why not go with a single-DIN and a flip up display? I had a nice Kenwood Excelon that had a beautiful flip up display. I got rid of it, put it in the wife's car, cause I got tired of it blocking my vents, but it did work fine.
And no head unit, other than factory/OEM, is plug and play on the '06 and up because of that G-forsaken CAN buss. You have to get a cable adapter kit to make it work.
Old 18 Mar 2011, 02:41 pm
Heading over to Island Audio in Victoria. Apparently they have done a few.
I will post the results.
Thanks for the reply's
Old 22 Mar 2011, 05:04 pm
Wink Re: Double Dinn
I always been a big proponent of a single din.
If you get a quality head unit; 6 pre out's 4 volts per pre out; sat radio; ipod etc;
YOU CAN TAKE IT WITH YOU REGARDLESS OF WHICH CAR YOU GET IN THE FUTURE.
I know alot of people that put in a nice double din head unit in their car/suv. then when they sell/trade it; they can't re-use it.
I seen someone get a $1,000 double din, DVD player, Touch Screen, Navigation, Bluetooth; then not be able to use it because they got a new car which was single din.
Old 22 Mar 2011, 08:53 pm
Cilos's Avatar
This guy cut out the plastic cross member in the dash to fit a double din
-Cilos
Old 22 Mar 2011, 08:56 pm
Cilos's Avatar
On my 09 I simply used a standard wiring harness.. connected to the stock plug and then crimped to my CDA-105's hardness.
Only thing I had to do was wire the radio's harness sides 12volt to the cig lighter since yeah, due to crack buss there is no 12volt power in the stock harness.
Course my system was non premium audio...
-Cilos
Old 06 Jun 2013, 10:32 am
Default 2006+ Pt Cruiser Double Din Bezel
Just to give everyone a heads up I found a Dould Din Bezel 4 the 2006-2010 PT Cruiser kit on Ebay . Not sure if it works. But it looks good. -
http://i29.photobucket.com/albums/c2...ps63952b0a.jpg
Chrysler PT Cruiser 2006 2010 GPS Navigation Double DIN Radio Bezel Install Kit | eBay
or just search ebay for 2006 pt cruiser double din bezel and you should be able to find it.
Have any of you tried this kit? I would love to see pictures.
Old 06 Jun 2013, 11:24 am
Default Use this company
This company can do it and a very reasonable cost. the kit makes it easy for anyone to install.
DoubleD Mods
Home Page
Old 06 Jun 2013, 11:27 am
I might also add that they actually own PT's and are older member here on the forum!!!!
double din unit AlexJB Sound and Security Forum 13 11 Aug 2014 07:04 pm
Double DIN confusion... JD78 Sound and Security Forum 11 06 Jun 2013 11:15 am
Double Din DVD Player Stizzle Interior Accessories Forum 3 03 May 2009 05:51 pm
What the H E double toothpicks is "lol"? Huh? Stephen R. General PT Cruiser Discussions 1 07 Feb 2003 01:41 pm
