Quick connect?
Old 23 Apr 2011, 10:15 pm
Dill's Avatar
Default Quick connect?
Im trying to think of a easy, inexpensive, and decent looking way of making connectors for my amps power, remote, and ground wires. The rcas are easy to do, The most important thing is that I want to keep the clarity of the 4 gauge power wire without downgrading it.
I basically want to be able to pull out the whole thing, amp sub and all
Incase i needed the space. I wouldnt want to use tools. Any ideas?
Old 03 May 2011, 10:04 pm
Default Re: Quick connect?
Well hook up your amp and sub as you would normally drive with it.
In the case you need to take the subwoofer box out of the car; Disconnect only the 2 wires that connect it to the amp (1 positive and 1 negative)
you want to keep a nice size roll of electrical tape in the trunk; because you want to cover up all the copper ends of the wire; until you re-connect them.
Old 03 May 2011, 11:25 pm
xwing777's Avatar
For power leads, I have used something like this on winches before:
Connector 175 Amp, Quick Disconnect, Anderson | eBay
Old 04 May 2011, 12:22 am
Dude, those Anderson connectors are what we use at work, they are mean muthas! You need a good crimp tool to make the connection though, unless you have some other way of doing that.
Old 04 May 2011, 07:27 am
Dill's Avatar
Lol thanks guys, ive went everywhere in town to no avail. Lowes suggested I buy a 50 amp power outlet for a dryer and just run a different wire to each socket in the outlet lol. Sounded too risky for me but wouldve been a nice clean install with everything just plugging in to one outlet minus rcas lol
Old 04 May 2011, 02:14 pm
Those anderson quick connects are sweet. learned something new today
Old 04 May 2011, 05:43 pm
They do make a smaller one for those. The one's he shows I think are 400 amp rated, way too much for what you're talking about. They have one's in red, blue, black and gray that are about half that size and way more efficient for what you want to do with your audio equipment.
Old 05 May 2011, 09:04 pm
Dam Chrome; you are dealing with major power.
Volts x Amps = Watts
14.0 x 400 = 5,600 Watts.
No doubt Dill isn't rocking 5,600 watts. His head unit is maybe 200 watts, and I think the amp he bought is 1,000 RMS & 2 ohms
Old 05 May 2011, 09:11 pm
Dill's Avatar
my polk sub is wired for 4 ohms, my pioneer is wired for 1 ohms, which btw sgt I think I wired the pioneer right for 1 ohm right?
I installed it today and did a bit more to my car, you can read about it at my blog site The Pickled PT, And Other Pickled Things. But I like those quick connects!
Old 05 May 2011, 09:43 pm
The most cost effective way to hook up a subwoofer is @ 1 ohm.
Some amplifers will only give you 500RMS @ 4 ohms; but 2,000RMS @1ohm.
It's important to always get a 1 ohm stable amp; so no matter what subwoofer/subwoofers set up you have in the future; or in your future car; you will be A - OK
Many amps are not 1ohm stable. Avoid them; as they can't handle 2 2ohm dvc Subwoofers.
Get a 1 ohm stable amp; and save some $$$$$ during this depression.
Hey Candyman! a quick Q.... Rowdy Exterior Accessories Forum 3 23 Aug 2009 04:28 am
How can I connect my iPhone? PurplePTGirl Interior Accessories Forum 2 16 Aug 2009 11:00 am
Just a quick one... Rooney Exterior Accessories Forum 10 31 Mar 2008 11:56 pm
I need help and QUICK before XMAS! euphmansgurl Exterior & Interior Styling 11 02 Dec 2003 09:04 am
Quick car wash tip turbomangt General PT Cruiser Discussions 8 11 Jul 2003 11:04 am
