No Volume on Radio
Old 27 Apr 2011, 08:45 pm
Default No Volume on Radio
I have a 2007 GT and I put it into storage over the winter. I disconnected the battery and after taking it out of storage I find the volume on the radio will not work. The radio powers up and the CD appears to function minus the volume. I disconnected the battery again hoping for a reset but to no avail.
Is there a relay or something like a fuse to the audio amplifier that needs to be reset or replaced?
Your comments are greatly appreciated....
Old 29 Apr 2011, 01:19 am
Default Re: No Volume on Radio
The Radio turns on; but the volume doesn't work.
Ok. I think I know whats wrong. Everything is getting power besides the internal amp and blew the fuse. The 10a fuse is the smallest fuse your entire car; so that one usually blows first.
This is an example picture of what I am referring to:
See the small fuse; it's red; and has a 10 on it.
Every head unit has a small amplifier, which produces about 20 watts x 4 interior speakers.
Sounds like when you hooked the battery back up; it slightly over loaded the electrical system.
That would explain the CD player turning on; but not the internal amp.
If the fuse is blown, you can buy a new one for about $2.00
I would check that before anything else.
Old 29 Apr 2011, 01:21 am
chris15's Avatar
Receiver and internal amp run off the same power lead. Checking the fuse is a good first step, but if the fuse was blown, the headunit would not power on whatsoever.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 29 Apr 2011, 02:10 am
Is this the premiun system? If so there are 2 fuses to check for the amp, #8 and #19. The premium system has a seperate amp and fuses than the radio.
Don
volume issue when playing a mp3? red06limited Sound and Security Forum 0 25 Feb 2011 04:50 pm
Radio turns its volume down by itself? AshtonPJ General PT Cruiser Discussions 6 23 Dec 2008 03:20 pm
More volume out of stock radio? Capt Kidd Sound and Security Forum 3 13 Jul 2004 05:06 pm
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
