Where to run amp pwr in manual pt
Old 30 Apr 2011, 11:39 am
Dill's Avatar
Default Where to run amp pwr in manual pt
The question says it all, theres hardly any space down with the pedals and no empty grommets like most suggest! Due to clutch I cant reach the hood latch grommet so I need somewhere to run my amp cable. Its 17 ft long so its long enough but I cant make too many odd turns, rca is ran along the passenger side so i cant run power wire down that side.
I have a drill but its pretty useless.
Old 30 Apr 2011, 11:45 am
Dill's Avatar
Default Re: Where to run amp pwr in manual pt
I will add that the local audio installers willl charge me 45 bucks to do this and theyre booked till next week!
Old 30 Apr 2011, 03:45 pm
I ran my power out through the same grommet as the hood cable release. Plenty of room in that grommet. It's on the driver's side of the firewall, near the left kick panel. There are pictures posted here somewhere from me running it. I'm not at home so don't have access to any of my stuff....
Old 30 Apr 2011, 04:13 pm
I had already answered this but then re-read the first post where it said you couldn't reach the grommet that the hood release used because of the clutch pedal. I deleted the post.
I'll re-post the HOW TO that's on the top of this sound section which shows the grommet and an empty space where the clutch pedal would be. You should be able to go around that pedal to reach the area where the hood release is.
Where to run amp power wire?
Old 30 Apr 2011, 05:55 pm
Dill's Avatar
I finally got it in after 3 days of trying lol. Eventually half cut my arm off weaving it through the pedals and wires etc... Ended up using a knife to repeatedly jab the grommet till it gave way enough for the wire to go through.. Whew!
Old 30 Apr 2011, 07:09 pm
I pushed through from the engine compartment. Took about 15 minutes.
What is the best car manual? matthewmilbut General PT Cruiser Discussions 6 30 Jul 2010 07:28 am
Shop Manual (service manual) DEEFIEND Tech & Performance Forum 2 17 Jan 2008 07:55 am
Best manual for an '03 GT? sawdust123 General Turbo Discussions 4 19 Jan 2005 11:46 pm
manual lenny General PT Cruiser Discussions 18 08 Apr 2004 10:30 pm
pt manual on cd $6 SHOVEL100 Vendors & Buyers Forum 5 13 Sep 2003 11:30 pm
