Alpine SPS-600C
Frequency Response 70 - 22000 Hz RMS: 160 watts per set / 80 watts each side MTX Audio TX6001 RMS: 180 watts per set / 90 watts each side Frequency Response 44 - 20000 Hz Alpine SPS-610C RMS: 160 watts per pair / 80 watts each (CEA-2031 Certified) Frequency Response 70 - 22,000 Hz Pioneer TS-A1604C Frequency Response 29 - 29,000 Hz RMS: 100 watts per pair / 50 watts each side The Pioneer is only 50 RMS; which is kind of low. However, they have the largest Frequency response range. They can hit the low bass notes; and the very high treble notes the best amongst all 4. Both Alpines have a 70 Frequency response, and are 70-80 RMS. I agree with you; the MTX are able to handle the most power @ 90RMS; and have the second best frequency response range @ 44hz. If you are amping them; I would go with the MTX. If you are running them off the head unit; I would get the Pioneer because the headunit puts out 20RMS; and the Pioneer will give you the deepest bass. - QUESTIONS: Do you have an amp, and/or a subwoofer? That would be the determining factor in my opinion. Peace ![]() Last edited by SergeantPtCruiser; 04 May 2011 at 04:04 pm. |
Can't debate that
Great quality; and 125RMS. those would thump and be very clear. They are double the price; but it might a good value still $200. ![]() |
I'm just using an Alpine CDA-117 and using the deck power for now.
I have a mono sub amp and subs not installed yet. |
![]() Quote:
If your going to have a sub, then your component can serve it's purpose of being a mid bass driver. you won't need a frequency response as low as the Pioneer @ 44hz. So frequency response shouldn't be your major concern. - The headunit gives about 20RMS per channel. If you are going to invest in some nice front stage components; you really need an amp. for them. If your planning on those Kick ass Polks; your amp should push 125RMS per channel @ 4 ohms Many 4 channel amps are only 50-75RMS, so make sure you keep that in mind. - ![]() ![]() I found one for you that is 125RMS x 4 @ 4 ohms. That would be perfect for the polks. Audiopipe is CEA certified. They are the best value for the dollar. They are know for being a value brand. I would get the Audiopipe amp; and the Polks if I were you. Amplifiers | AQX-360.4 • Power Amplifier: 2500 Watts • Channel: 4 Channels Class AB • Frequency Response: 20Hz - 30KHz • Bass Boost: 0-15dB @ 45Hz • Input Level: 0.2-6V • Crossover Range: 55Hz - 550Hz • THD: <0.08% • Output Power (RMS): 4 Channel @ 4Ω - 125W 4 Channel @ 2Ω - 180W 2 Channel @ 4Ω - 360W • Dimension: 433x182x66mm $147 (free shipping) AQX-360.4 | eBay |
Thanks for the input guys.
Im going to try to get the MTX speakers. Should be installed with in the next couple of weeks. ![]() |
Question to SergeantC., why is it you post a one or two liner post and then 20mins or so later it turns out to be almost an entire page?
Should at least post a footnote as to what you edited and why. You've done it for just about 95% of your posts and it's confusing as hell. |
![]() Quote:
I am assuming people could benefit form seeing the actual model in a picture; and a link to see it's specs. I didn't know adding something would be confusing; rather; i thought it would clear things up more. But whatever; I am not going to write why I edited. And 95%; man, you keeping tabs? That is weird.. ....anyway; let's try to stay on topic ![]() Last edited by SergeantPtCruiser; 05 May 2011 at 04:03 pm. Reason: Because I can; 95.5% now. |
Thread Tools | |
Display Modes | |
Which cold air intake did you choose? | Undergfx | Turbo Performance | 10 | 29 May 2010 01:36 pm |
which to choose? | PT17 | The Detail Shop | 10 | 19 Sep 2008 07:13 am |
Help me choose a system for my convert... | Ramon | Sound and Security Forum | 3 | 02 Jun 2004 10:38 pm |
which to choose | JaxPT | Wheels, Tires, Suspension | 8 | 28 Dec 2003 04:50 pm |
