Wiring up 2 Ohm Subs
Old 31 May 2011, 03:45 pm
Default Wiring up 2 Ohm Subs
Hey guys,
Quick question: I am installing a friends MTX Terminator two 12" subwoofers with an arctic amp. The output of the Terminators (they came like this) is one terminal at the back of the box that says 2O. Currently, I have it set up where the positive cable is on the first channel and the negative is on the second channel. The amp says it is bridgeable. Am I okay to keep it wired like this, or should it be changed?
Thanks!
Old 31 May 2011, 05:37 pm
chigger_ns's Avatar
Default Re: Wiring up 2 Ohm Subs
We need model numbers
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 31 May 2011, 06:04 pm
Sure it doesnt say 2Ω ? lol Just kidding
I agree with chigger, model #'s for the amp would be good.
Old 31 May 2011, 07:59 pm
Hey guys,
Thanks for your help!
The amp is a Pyramid Arctic PB717X: Amazon.com: Pyramid PB717X 1,000-Watt 2-Channel Bridgeable Amplifier: Electronics
The subwoofers are the MTX Terminator TNE2120 model number: Amazon.com: MTX Audio Terminator Series TNE212D 1200 Watt Dual 12" Sub Enclosure: Electronics
Old 31 May 2011, 08:57 pm
Specs:
Bridgeable
Delivers two channels or bridge mono for subwoofers. The PB171X cranks out 2 x 50 watts RMS at 4 ohms and is 2-ohm stereo stable for 75 watts x 2.
It says 2 ohms because it's 2 ohm stable.
The amp only puts out 75 RMS watts per subwoofer (x2)
Those Watts are not CEA certified; so it's likely less. Even if it was 75 watts, that is VERY low for a subwoofer.
subwoofers:
MTX Terminator TNE212D Dual 12" Sealed Subwoofer Enclosure | shop.mtx.com
Part Number: TNE212D
Description: Dual 12", Terminator Sealed Enclosure w/Amplifier
Frequency Response +/- 3dB: 37Hz - 150Hz
Depth: 11.125" (28.26 cm)
Impedance: 2O
RMS Power (Watts): 400
Recommended Amp Power (RMS): 200 - 400
***The Subwoofers are OK. 400 RMS is decent per subwoofer.
However, the amp claiming to putting out 50-75 RMS (not CEA certified, so it's probably lower)
The amp is not a good match for the subwoofer. It's grossly underpowered. That can damage your subwoofer.
*I am not putting you down, just evaluating your equipment in an honest way based on the manufactures specs.
If I were you, I would get some decent equipment if you enjoy Bass. Value how much you like bass.
To start, I would start with a new amp. You want your amp to be slightly more powerful than your subwoofers; so you don't abuse your amp. Keep the gains turned down to increase lifetime of the amp while providing the proper RMS watts to the subwoofers.
The Subwoofers you have now; the MTX entry line, are OK. You can stick with them; but consider getting the proper amp for them.
Old 31 May 2011, 09:01 pm
Thanks for your help SergeantPTCruiser. It's not my setup, and the person using them won't be using them at full power and isn't particularly concerned with sound quality.
Is the way I have them wired, as shown in the picture that you displayed, safe to use? (I copied the picture below for reference.)
Thanks again for all of your help!
Old 31 May 2011, 09:14 pm
The amp also has a lot of very bad reviews.
Amazon.com: Customer Reviews: Pyramid PB717X 1,000-Watt 2-Channel Bridgeable Amplifier
It's crazy how it says 1,000 watts, but really is 100-150 RMS
Old 31 May 2011, 09:22 pm
lol, don't worry bro; it's not my copy write picture, even if it was, I wouldn't care.
Ok. You asked about the 2 ohms.
Check it out. you gotta check how your subwoofers are wired.
I believe those are Single Voice Coils or SVC
Check this for reference, and maybe bookmark it.
Subwoofer Wiring Diagrams
And if you have it hooked up 1 positive on the left terminal, and 1 negative on the other terminal, that is Correct if the sub woofers are wired together.
The 2 channel amp is usually 1 terminal per speaker; unless the speakers themselves are wired together. If they are wired together; then the way you have the wires in the Amp is Correct
peace!!!
Old 31 May 2011, 09:32 pm
I am not sure how these subs are wired inside the box. My friend says they came in the box like that. On the back of the box, there is one set of terminals that says 2 Ohms.
Old 31 May 2011, 09:50 pm
Yeh, Pyramid isnt the greatest, I'd stay away. Sonic Electronix has a lot of good equipment cheap. That's where I got my amp.
Two subs to one amp? Delicroix Sound and Security Forum 18 13 Oct 2010 11:22 pm
Show me your subs!!! jbaer1 Sound and Security Forum 12 03 Apr 2010 02:25 pm
Subs/Amp F/S StoneWhitePT2 Classifieds: For Sale/Trade 0 04 Jun 2009 10:05 pm
2 12" subs w/amp and wiring Tw3NTy0n3 Classifieds: For Sale/Trade 0 05 Jul 2007 02:14 pm
how many decibals do your subs hit??? DBROWN03 Sound and Security Forum 15 30 Jun 2005 10:40 pm
