Security System Question
Old 14 Jun 2011, 10:03 am
Default Security System Question
Well, I don't see any other questions about security on this post, but I'll give it a try...
Following the last time a certain mechanic looked at my car, every time I lock the car in a manner that activates the security system, the alarm goes off 10 minutes later. This alleged mechanic (he's not on this list) doesn't believe he did anything, since he was looking under the hood. He refuses to repair it at his cost.
I have all of the manuals for the car, but I dont see anything that tells me details about the factory security system. I take it they do that for, well, security reasons. Unfortunatelly, that leaves me high and dry in terms of troubleshooting it myself.
Can anyone offer any guidance here?
Thanks!
Chuck
http://www.chuckles.net/car.php
Old 14 Jun 2011, 04:27 pm
xwing777's Avatar
Default Re: Security System Question
Is your an early model like 01, 02? Reason i ask the early models had a switch (drivers side at back of hood) that was wired into the alarm. If he was under the hood he could have bumped this switch or broke it causing the alarm to go off.
If yours is later model they did away with that switch but there is still a hole for it on all models.
Old 14 Jun 2011, 04:32 pm
Yes, it's an '01. Does the switch look like a plunger? When I put on the reverse-opening hood, I removed it from its holder, but it's still wired up.
Thanks!
Chuck
Old 14 Jun 2011, 04:40 pm
xwing777's Avatar
Yes thats it. Try some tape to keep it closed or if its got 2 wires, you can shunt it by stripping the wires and twisting them together.
Old 14 Jun 2011, 04:41 pm
I just looked at that switch and it and the wiring don't look damaged at all. The plunger separates from the connector. I wonder if I separate the two, if that'll fix it? I have stuff to do tonight, will play with it tomorrow. Good thought!
Thanks!
Chuck
Old 14 Jun 2011, 04:45 pm
xwing777's Avatar
That should be a normally closed circuit, so connecting them together will take it out of the system.
Old 14 Jun 2011, 04:47 pm
I was posting my last message while you were posting this.
It was several years between replacing the hood and seeing this problem. The switch has been set as if the hood is open and it hasn't gone off. What you are saying sounds right, but it all seems backwards.
Hhhmmm...
Thanks!
Chuck
Old 14 Jun 2011, 06:26 pm
That is New Jersey.
I been all over the USA while I was in the army. Virgina, Texas, California,
I have to say the shadiest places in the USA are
1. New York City (not state)
2. New Jersey
Jersey is the most populated state per square mile.
Old 14 Jun 2011, 08:31 pm
Originally Posted by SergeantPtCruiser View Post
That is New Jersey.
2. New Jersey
Good call! This guy is originally from Brooklyn.
Thanks!
Chuck
Old 15 Jun 2011, 11:16 am
Hi XWing,
I removed the plunger and put a paper clip into the connector to effectively do the same thing-short out the connection and make the car believe that the hood is closed. But, it didn't work. A couple of minutes later, the alarm went off again.
I guess that strictly speaking, if the wire is broken anywhere before that connector, the paper clip trick would not be doing anything. That could be the problem, or there might be a connection to another sensor somewhere in the car that could having a problem. If only I had a wiring diagram similar to the the rest of the car, I could go through them all.
Hhhmmm...the plot thickens!
Thanks!
Chuck
Replacing Chrysler's OEM Security system. Any advice? Kell Sound and Security Forum 0 23 Sep 2010 02:27 am
Disabling the PT Security System? thender General PT Cruiser Discussions 7 19 Dec 2009 12:33 am
New security system careyk General PT Cruiser Discussions 1 30 Oct 2008 01:39 pm
What security system you running? Opiate Sound and Security Forum 1 13 Jul 2004 04:49 pm
Security question..... dbraveman Sound and Security Forum 12 07 Jan 2004 07:10 pm
