How To NOT Tear Up My PT. Have Questions.
Old 04 Jul 2011, 08:47 pm
Default How To NOT Tear Up My PT. Have Questions.
Ok I am hoping that next weekend that I will be installing my new head unit. Now I have not seen too many installs from start to finish...
1 - is there anything I need to watch out for when I take apart the dash, what is the easiest way to do this.
2 - on the 2008 the rear speakers are in the rear doors, whereas my 2001 had speakers in the rear pillars, is there still mounting points if I wanted to put speakers there?
3 - anything else i need to watch for?
Thanks!
Spooky
2008 Touring Edition 26,000 Miles
R.I.P. Penny
2001 - Limited Edition - 234,067 + Miles
120,000 – spark plugs – Bosch Platinum 4
135,000 - Timing belt,
170,000 - Radiator
190,000 – PCV and hose
200,000 – Spark plugs Bosch Platinum IR Fusion
200,235 - Oil Sensor
Old 04 Jul 2011, 10:42 pm
xwing777's Avatar
Default Re: How To NOT Tear Up My PT. Have Questions.
Often overlooked are the 2 screws behind the vents. There at the bottom portion and you may need to rotate then and use a light to see them. Once these are out, use your hands and pop the bezel out.
Yes the opening are still there but you would have to change out a lot of the plastic covers to make them work (i think all of the rear plastic to get everything to line up)
Depending on the kit you got, some mount over the radio after its installed, some mount first then the radio, so check fit before screwing everything up. Also make sure you have an antenna adapter as the factory antenna wont plug into aftermarket radios.
I have had my wifes 06' tore apart from front to back:
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
2 Questions jmack General PT Cruiser Discussions 3 29 Sep 2004 03:51 pm
Tear Drop door handle molding phantomcruiser Interior Accessories Forum 10 05 Aug 2004 11:15 am
roof tear - damn it Mongo General PT Cruiser Discussions 6 29 Jul 2003 05:35 pm
Tear Drop Lights rix milligan Classifieds: For Sale/Trade 0 25 Mar 2003 05:47 pm
