dumb question about radio access
Old 07 Jul 2011, 01:07 pm
Default dumb question about radio access
Hey, either they haven't made one yet or my local parts houses don't carry Haynes/Chilton manuals for the PT Cruiser. All I need to know is how to access the back of the radio where the antenna plugs in (I'm installing an HD radio module). Does the plastic panel which surrounds the radio/vents/etc. simply pull off or is there more to it? I have only had the car for a few months and don't want to break anything yet.
Thanks in advance.
Farrar
2006 Chrysler PT Cruiser Turbo: 108,700 miles
1981 DeLorean DMC-12: 78,000 miles
Old 07 Jul 2011, 01:12 pm
Dill's Avatar
Default Re: dumb question about radio access
What year? Fr mine u pry off the window switch, then unscrew a screw there then pry off the whole panel then u screw the radio and remove
Old 07 Jul 2011, 01:15 pm
Originally Posted by Dill View Post
What year?
Oops! Sorry, I forgot -- it's a 2006. Told you it was a dumb question.
Thanks! I will try this. Very excited about adding HD Radio to my car without removing the stock head unit.
Farrar
Old 07 Jul 2011, 05:05 pm
2006 and up is different. There are 2 screws inside the center vents at the bottom. They are about 2 inches deep and you have to rotate the vents until a hole lines up with the screw. Once these 2 screws are out then you just pry the whole cover off. You will need to get 2 adapters since Chrysler does not use a standard antenna connector. Ford also uses the same connector.
Don
Old 11 Jul 2011, 12:36 am
Thanks for the info, Don! I'll check for one of those adapters the next time I'm at AutoZone.
Farrar
Old 09 Dec 2011, 12:48 pm
06ptcruzr's Avatar
Farrar, I would love to get details on this. How did it work out for you?
If it's easy, I would love to have access to HD radio stations via my stock 2006 radio.
"PTCRUZR" : 2006 Magnesium Pearl Touring Edition : www.PTCRUZR.com -- Bill Gerrard's Automotive Photography
REALLY DUMB QUESTION!!!!!!! 2002ptcruiserwoody723 Tech & Performance Forum 10 14 Nov 2013 01:34 pm
Maybe dumb question gonzomania The Detail Shop 4 16 May 2006 04:14 pm
Sorry for the dumb question crazie.eddie Tech & Performance Forum 3 27 Sep 2004 08:14 am
Dumb question #1 GT Kruzr Turbo Performance 5 22 Apr 2004 11:13 pm
yet another dumb question GTcamster General Turbo Discussions 18 22 Apr 2003 06:47 am
