BIG 3 -
Old 03 Sep 2011, 09:38 am
Default BIG 3 -
Ok guys so the other night I was on my way home, raining like hell, crazy drivers from hell, a/c cranked, windshield wipers at warp speed, headlights on then Hells Bells was playing so I cranked it up and low and behold my lights started to dim with each bell toll. At first I thought the 4 horseman were on their way so i switched songs, yeah like that would stop the 4 horseman, but even Katy's E.T. dimmed my lights, and yes I am sure the mother ship was not call me home.
So are there ready made cables to do this? I have already picked up some new battery terminals, anyone have a good instruction to save some time and money?
These are the terminals I picked up
Platinum Finish
High End Battery Terminal
1X 1/0 Gauge Input
1X 4 Gauge Input
2X 8 Gauge Inputs
Spooky
2008 Touring Edition 26,000 Miles
R.I.P. Penny
2001 - Limited Edition - 234,067 + Miles
120,000 – spark plugs – Bosch Platinum 4
135,000 - Timing belt,
170,000 - Radiator
190,000 – PCV and hose
200,000 – Spark plugs Bosch Platinum IR Fusion
200,235 - Oil Sensor
Old 03 Sep 2011, 06:56 pm
Default Re: BIG 3 -
Dude, those are some gorgeous terminals! Me, personally, I'm going with solder on lugs for the 1/0, but want a bolt on terminal like you're showing. Where did you find that one? It's really a beautiful piece. As to the cables, depends on where you are. I found some 1/0 that's blue, black, red and yellow, take your pick. Way too expensive for my taste so I'm still looking around. I also posted on LowPT's thread about the Big 3 mod, I'd like to see what he did, he's quite the creative character.
Old 03 Sep 2011, 07:18 pm
Default Re: BIG 3 -
Techno- the problem I see with that terminal is if you plan on running 1/0 there is only one spot for it. You need more than one. There will be one from the altenator to the battery and at least one to your system.
Chrome- check out your local welding supply for wire. It will be solid copper (not copper coated aluminum), very flexible, better insulation, and usually much cheaper.
Old 03 Sep 2011, 07:34 pm
Dill's Avatar
Default Re: BIG 3 -
Where u buy those at? I want those!
Old 03 Sep 2011, 11:31 pm
Default Re: BIG 3 -
The best place on earth Ebay!!!
Some have them listed as RAPTOR battery terminals.
Spooky
R.I.P. Penny
170,000 - Radiator
Old 03 Sep 2011, 11:41 pm
Default Re: BIG 3 -
So the 4 gauge will not be enough? I was going to get a Power Distributor Block for when I run the cable to the amp to have extra ports for some leds or future stuff. I have seen a couple of the 1/0 fuseable links that I could run 2 lines if I needed.
Spooky
R.I.P. Penny
170,000 - Radiator
Old 03 Sep 2011, 11:43 pm
Default Re: BIG 3 -
Ebay, i was dead set at getting the ones with the built in digital voltage then I saw these and was like, man I can add alot of stuff now...
Spooky
R.I.P. Penny
170,000 - Radiator
Old 04 Sep 2011, 12:53 pm
Default Re: BIG 3 -
I personally do not like that "style"(set screw) of terminal. But I have used them without problem an have also used them where they have given me nothing but fits(Wires not wanting to stay snug).I have run into charging issues with those "style" terminals before also (The coating I guess?), but again have used them without issue.
4ga should be plenty for the big 3 , assuming you do not have some crazy power being pulled you shouldn't have a need for 1/0 .. though it wouldn't hurt.
2003 PT .. Stock besides tint an audio.
Pioneer 8600
Suprisingly crisp stock mids/highs (for now).
2 - image dyamic ID 8's
1.8 cubes tuned 30hz
Old 04 Sep 2011, 03:11 pm
Default Re: BIG 3 -
Techno what size amplifier(s) are you running? 4 gauge is good for the 140-150 amp range. So, unless you have upgraded your altenator, it should be ok to use it for the big 3. And as long as you are under 1400-1500 watts it should be ok for power to the amps.
Old 04 Sep 2011, 05:16 pm
Dill's Avatar
Default Re: BIG 3 -
Snce these terminals would be permanent, i would go to somewhere that sells electrical supplies and buy a conductive glue or something... Id fill the hole for the wire with a decent amount of the goo, put in the wire and screw the screw tight.
