I just purchased a 2001 PT Cruiser July 2011 from a Chrysler dealer and she seemed fine. I suddenly am discovering that the doors and hatch unlock by themselves. I read some of the other posts. I have done the following: I did change the batteries on the remote. I changed the 10A and 20A fuses. I have not gone into the fuse box under the hood yet. I have also experienced the alarm making random honking noises. When I purchased the vehicle, I was not informed that the hatch lock had been soldered closed. At first, it was not a concern because the keyless entry was working perfectly. However, when the hatch does not open I cannot get inside. Is there a manual button to lock and unlock the hatch? When I hit the remote I definitely hear a click however the locks do not close. I have to do this manually. When I hit the keyless remote button to close the doors it sounds off the alarm giving the impression that it has locked the doors and the car is secure however, that is not the case as everything is unlocked. In addition, it now unlocks on its own. Is there a way to disconnect the alarm so that the locks are not randomly opened? How would that affect my access to the hatch? Whew! now let me catch my breath.
Bummed out in Brooklyn |
If the locks are cycling on their own, you have a bad lock cylinder switch. Put your key in each door lock and lock and unlock doors. One (usually the drivers) will most likely make your locks cycle like crazy will very little input or will cycle the locks with hardly turning the key at all. That's the bad one.
u need to change the wireless key... which is with you...
There are several things that can be going on:
The first and easiest is to do what Floundering said. If that doesn't give you any answers, you're going to chase you RKE. I know Crusin' has a diagram of it somewhere. Im sure he'll put it up as soon as he sees this post. The diagram helped me. And by replacing the RKE, it fixed all my strange lock and unlock issues. RKE = Remote Keyless Entry Module. |
Here ya go.
![]() Quote:
I finally discovered (thanks to Floundering) that the drivers side door cylinder switch is dead. Is this why the remote transmitter doesn't unlock the car?? I will try and get a new one to replace it. Any guides out there on how to do it? Thanks in advnce!! |
Thread Tools | |
Display Modes | |
keyless entry help!! | superbert1971 | Tech & Performance Forum | 4 | 28 May 2010 08:51 pm |
keyless entry | chintzgirl | General PT Cruiser Discussions | 3 | 29 May 2009 07:12 pm |
keyless entry | dpmeeks | General PT Cruiser Discussions | 6 | 13 May 2009 05:52 pm |
KEYLESS ENTRY? | DevilMan | General PT Cruiser Discussions | 1 | 01 Apr 2006 08:48 pm |
Keyless entry? | Blade | General PT Cruiser Discussions | 13 | 22 Mar 2004 05:52 pm |
