PT Cruiser Forum Car Videos
Custom Wheels
Factory alarm add-on
Old 06 Feb 2004, 09:23 pm
dbraveman dbraveman is offline
Default Factory alarm add-on
its called EVS II/IT-s interior theft sensor..has anyone installed this?
i'm looking to improve my security sys and instead of adding a complete passive like clifford or prestige,i thought this was a better idea
any thoughts?
Old 07 Feb 2004, 04:03 am
2sb 2sb is offline
Ours is an 02 base model. I installed one called just EVS. It's just a siren and starter disable. Since it has no power door locks, I don't know if it would operate them. The install wasn't hard...except for the (#$$%&)wire under the battery. I chose this system because I know it's compatible and, as a DC product, it's covered under the car's warranty.
P.S. When I picked up the PT, I ordered the manual the same day.
Old 07 Feb 2004, 11:33 am
ElectricBlueGT ElectricBlueGT is offline
The interior theft sensor is the same infrared shock sensor CodeAlarm uses for their alarms. Awesome piece. When it is properly adjusted, you should have no false alarms (ok, MUCH less than any other shock sensor).
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 08 Feb 2004, 02:31 am
ok,first positive opinion(a lot of negative in ptenthusiasts)
electricblue,was it an easy install?
\'03 GT,Patriot Blue ,autostick,BTG Catback,Airaid CAI,APC Gen 3 retro
tail lights,chrome spears,chrome grille..http://www.cardomain.com/memberpage/523715
Old 08 Feb 2004, 03:12 am
dbraveman,
I have not installed one on a Chrysler system, but have done the CodeAlarm setups before. Basically, the sensor is a plug-and-play affair. The sensor plugs into a port on the alarm brain. There is a knob on the side of the sensor to adjust its sensitivity. I would assume (watch that word...) that the sensor has an instruction sheet in order to help setup. Make sure you mount the sensor on a solid surface (firewall, if possible). This will help to ensure that less false alarms occur.
Scott
vB code is On
Factory Car Alarm bh99 Sound and Security Forum 3 24 Jul 2005 02:39 pm
Remote start with factory alarm SwtNLwPT Sound and Security Forum 0 14 Jul 2004 10:19 am
Car Alarm??? lightyears Sound and Security Forum 12 07 May 2004 04:08 am
'Factory Alarm'???? knowyourturbo Sound and Security Forum 1 06 Jan 2004 02:31 am
Factory Alarm made Passive? SRG Sound and Security Forum 6 17 Mar 2003 02:47 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Online Loans | Loans | Loans | Debt Loans | MPAA
