PT Cruiser Forum Car Videos
Car Rims
stronger alternator
Old 25 Feb 2004, 08:07 pm
milPT milPT is offline
Default stronger alternator
Has anyone had to get an alternator that provides more power then the stock one? Just out of curiousity because I have my own sound system that I run a lot at parties and get togethers along with undercarage lights. I plan on adding more things that will use the electric and wondering if its best to get another battery or a better alternator?
Old 25 Feb 2004, 10:29 pm
Sounds like battery should come first if you're planning on using sound system at parties (car off). Just a thought - maybe throw a long extension cord (100' or so) and battery charger in the car, and plug in your PT.
Old 26 Feb 2004, 12:43 am
JaxPT JaxPT is offline
If you're looking for running a system with the car off what ya need to invest in a a battery isolator and another battery, a deep cycle, most people go with Optima Yellow Tops. one battery is just for primary functions, starting etc. and the deep cycle is for powering the system without draining your main battery.
Old 26 Feb 2004, 01:06 am
ElectricBlueGT ElectricBlueGT is offline
JaxPT,
A better choice is a battery isolating solenoid contact switch. The solenoid is ignition triggered to be closed when the car is on to allow the batteries to be charged from the alternator. The solenoid is open when the car is off. The system and aftermarket accessories can be run off the second battery. If the second battery "dies", the car can still be started from the main battery. A diode battery isolator has a voltage drop of 1 to 2 volts. This voltage drop only strains that alternator even more. A good solenoid contact switch has a voltage drop of 0.01 volts.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 26 Feb 2004, 08:22 pm
thanks for the advice, any idea of general cost?
02\' Patriot Blue Cruiser, dual cat back exhaust, blue under car lights, airaid cold air intake, throttle body spacer and custom sound system.*Xenon front bumper (crusher), polished aluminum gas door.
Old 27 Feb 2004, 01:15 am
milPT,
The solenoid switch should be ~$100. 4 gauge wire ~$2.00 per foot. Battery: depends on who you buy from...Optima Yellow Top (deep cycle) is a good choice.
A deep cycle battery is good for repeated fully-charged to dead battery cycles. A normal car battery is good for 2 dead battery scenarios, then it will never act the same...(per AutoSound 2000 tech article ~ 10 years ago)
Scott
vB code is On
$817 rip off you decide PT Lilly General PT Cruiser Discussions 13 25 Aug 2005 07:55 pm
Advice on Alternator and Batteries PT Lilly General PT Cruiser Discussions 1 11 Jun 2005 12:25 pm
alternator? DARK270 General Turbo Discussions 13 07 Mar 2005 02:27 am
Pt is running stronger then before? KingKole02 Tech & Performance Forum 3 16 Apr 2004 03:00 pm
Alternator Mark Tech & Performance Forum 0 13 Feb 2002 05:46 pm
  Internet Advertising | Homeowner Loans | Credit Card | Mortgage | Loans
