Aftermarket horn installation need help
Like Tree4Likes
Old 04 Jan 2013, 11:20 pm
Default Aftermarket horn installation need help
I found an air horn that I want to replace my OEM with. It only requires 12 volts. Do I just use the stock wiring or do I need fuses/relays? Please help me out! Thanks in advance!
Ps. I have a 03 pt cruiser non turbo
Old 05 Jan 2013, 01:15 am
Default Re: Aftermarket horn installation need help
It depends on the power requirements of the air horn. Some information about it would help?
mityqwik likes this.
Old 05 Jan 2013, 01:18 am
needmoretoys's Avatar
Is it an airhorn with an air tank and compressor or just one of the little 2 red horn jobs? Are you hooking up in place of your stock horn? If you are hooking up a compressor then you have to run wires the correct way using the stock horn button as the trigger. If you are installing the little red(or whatever color) plastic horns then you can just hook it up to your stock horn wires in front of the car in place of the stock horns. Your new horns should come with instructions. Good luck.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 05 Jan 2013, 02:56 pm
It is just the small compressed with the two small horns
Old 05 Jan 2013, 07:21 pm
That little compressor will have 2 wires 1 hot and 1 ground(should be black) Just tap the hot wire into the wire from your stock horn and put the black to a ground. Should be very easy.
Lenny
Old 05 Jan 2013, 07:25 pm
You forgot to mention a relay? If it has a small compressor the amp draw may be greater then the oem horn wire circuit can carry? I am sure the kit he got has one if not it is a wise investment to install one.
needmoretoys I always get a kick out of your user name since I joined always think "How true" !!
oh and my best friend since High school calls me Lenny LOL
Old 05 Jan 2013, 09:56 pm
Thanks guys! I installed it about an hour ago and I installed another relay just to be on the safe side. Sounds awesome!
Old 06 Jan 2013, 01:06 am
Got pictures.... auh ..... ytube of the sound?
I have been thinking the same thing to upgrade the oem myself horn. I mean wow, I blow the horn and people look at the person riding the bicycle next
to me ?
Old 06 Jan 2013, 11:22 am
to me ?
Ill put up a vid of the sound today sometime. It was really easy to install right under the fender in between the mud flaps. Yeah I got sick of my bike horn. Picked this one up at harbor freight for under $20 it sounds awesome!
Old 06 Jan 2013, 11:29 am
Oh ya....
I would like to hear them on your PT!
12 Volt Super-Loud Air Horn
Tags
horn
Aftermarket Radio Installation bjagd02 Sound and Security Forum 3 01 May 2011 01:56 pm
air horn installation not going good jacquesfrosty Tech & Performance Forum 5 03 Apr 2011 07:56 am
2nd Horn Installation Merlin1 Tech & Performance Forum 15 19 Feb 2011 08:17 am
Oogah horn installation kfrankl3 General PT Cruiser Discussions 5 04 Aug 2008 07:39 pm
Aftermarket BOV Installation Chipmunk Turbo Performance 9 27 Apr 2003 01:41 am
