Any convenient tap points under dash for +12 Constant?
  • 1 Post By sanatanadharma
Old 03 Feb 2014, 03:23 pm
Default Any convenient tap points under dash for +12 Constant?
It would be for parking lights, so only ~3A-ish draw.
Old 03 Feb 2014, 03:49 pm
Handy_Cruiser's Avatar
Default Re: Any convenient tap points under dash for +12 Constant?
The feed to the power outlet on the floor console should likely do the job.
BUT - why do you need a new feed for your park lights? That's really the bigger questions.
Old 03 Feb 2014, 03:56 pm
It's for the remote start I recently put in. It has a provision to turn on the parking lights while the engine is running.
It works fine without that but I decided to go ahead and install it.
Old 03 Feb 2014, 05:22 pm
Bend down below the dash and look up toward the fuse block. Look for the big white connector (next to the grey). It should have three hot battery circuit pins; Pin #3, red 14 gage, Pin #11, yellow 14 gage, Pin #6, pink/dark green lighter gage.
The back of the fuse block is another good place to look.
Caveat!!!!
You have a 2007 (I believe, shouldn't have to look before offering answer).
If so, as a second-gen canbus design, your mileage may vary. Use a voltage testor.
randyincctx likes this.
Old 04 Feb 2014, 05:30 pm
My appologies, I should have specified it is a 2007.
The lighter socket is probably a decent source.
I don't think the new one has a fuse box inside the cabin, but I can certainly look.
I had just tried searching the forum and couln't find any relevant matches... like you pointed out on the Gen1 fuse box there are often convenient tapping points that don't require screwing with the factory wiring harness. I was hoping for the same on mine.
In any case... the next one who searches now WILL get a relevant hit, LOL.
Last edited by TroyO; 04 Feb 2014 at 05:31 pm. Reason: My spelling of screwing was... err, screwed.
Old 04 Feb 2014, 08:16 pm
My bad. You are correct that there is no dash-fuse block in the second-gen; no tap-a-fuse possibility.
Originally Posted by TroyO View Post
I don't think the new one has a fuse box inside the cabin, but I can certainly look. ...
Constant road noise over 50 MPH bfretless Wheels, Tires, Suspension 21 22 Jun 2013 06:18 pm
Lube Points? MCM Tech & Performance Forum 4 11 Apr 2010 06:57 am
Lube points under PT Cajunsim Wheels, Tires, Suspension 5 22 Jul 2009 09:15 am
BEST RPM SHIFT POINTS MEXICANPT Turbo Performance 8 08 Sep 2003 07:57 pm
